budget studio monitor advice
Post by SonicAdam »
I'm looking to purchase a new pair of active studio monitors and spend hopefully no more than £300 cos at the moment money is tight at the moment!
I've been looking at a few different models so far ..
KRK RP5 G2 - around £260ish
M Audio Studiophile BX8a - £230
Fostex PM 05 MKII - £275
Alesis M1 620 Active - £300
Has anyone had any experiance with any of these ones or could anyone recommend any others that ive not listed?
any help would be greatly appreciated!
AdamC'
SonicAdam
Posts: 42 Joined: Mon Sep 17, 2007 12:00 am
Re: budget studio monitor advice
Post by EnlightenedHand »
Well if you need to just get started then jump in with any of those really. None of them are all that useful for serious, consistent critical listening. But any of them will get you started. I've personally used the older KRK rokits and I think for inexpensive loudspeakers (at the ridiculously low price that they're at) they can suit the task of mixing once you get to know them and provided that you have a properly treated acoustic space to work in. But it will ultimately be a bit of an uphill battle when working with low costing loudspeakers and you will definitely outgrow them as you get more experienced.
Liz
EnlightenedHand
Posts: 589 Joined: Fri Jan 18, 2008 12:00 am Location: United States
Post by SonicAdam »
Thanks Liz,
I appreciate it will be an uphill struggle, and i would prefer to go for more expensive ones, because i do agree that i will grow out of them as i get more experienced, however i'm a student at the moment, so ive got alot of expenses! :P
SonicAdam
Post by Big_al »
Try the Yamaha HS50M's only about 215 quid a pair, and they translate beautifully across different systems. I've mixed on them and my mixes sounded great from club systems and car stereos!
Big_al
Posts: 233 Joined: Fri Sep 30, 2005 12:00 am
Post by adrian_k »
check my reply on your other post
cheers
A
adrian_k
Posts: 3813 Joined: Thu Jan 30, 2003 12:00 am Location: Gloucestershire
Life is wealth. (John Ruskin)
Post by SonicAdam »
thanks you guys
could a mod close this post because ive stupidly started 2 posts lol! :headbang:
SonicAdam
