Really Crappy Midi sounds???!!!
Post by Freuman »
Hello all, Just wondering if I'm missing something:
I am set to record a cheesy comedy band and I am in desperate need of really crappy GM sounds!
I run Pro Tools on Mac and have hundreds of decent VIs but cant seem to find anything that sounds bad!
:headbang:
I know the ideal solution would be to buy a Casio keyboard or some kids toys, but I don't particularly want hardware.
Please help!
Freuman
Posts: 417 Joined: Tue Jun 10, 2008 12:00 am Location: Southend-On-Sea, Essex, UK
11011110110010101111 - 110000001111111111101110 - 101110101101 Hexadecimal binary coding anyone?
Re: Really Crappy Midi sounds???!!!
Post by Zukan »
What's the budget saying?
Because there are some good ones out there, Omnisynth, Colossus etc.
Does your sound card not have any GM sounds. Microsoft GM Wavetable Synth might work.
Zukan
Posts: 10135 Joined: Fri Sep 12, 2003 12:00 am
'Shaka. When the walls fell. Zukan...with his arms wide.'
1-2-1 Tuition
Post by Freuman »
If I can do it for free I would love you forever!
"Omnisynth, Colossus etc." are a bit too good for the kind of thing I need. The best (worst) I have is "Structure" (that has some fairly bad sounds).
:beamup:
GS Wavetable Synth would be perfect (or Apple equivalent...or whatever), but I'm not sure how to route this in PT so it outputs the GM sounds.
(Can you tell I'm not a big MIDI user?)
Freuman
Post by Sam Inglis »
You could try the Xpand! soft synth that comes free with PT -- I think that has a GM bank. There are also freeware and shareware ones out there but I imagine most of them are VST/PC rather than RTAS/Mac. If you can find some in Mac AU or VST formats, FXpansion's excellent VST To RTAS Adapter will let you use them in Pro Tools.
Sam Inglis
Posts: 3228 Joined: Fri Dec 15, 2000 12:00 am
Post by muzines »
Try the Mac's built-in Quicktime Synth.
Nice, small cheesy GM soundset.
muzines
Post by jrbcm »
You could seek out the Roland virtual sound canvas (VST plug?). Should be suitably duff...
jrbcm
Posts: 294 Joined: Fri May 13, 2005 12:00 am
Post by Freuman »
I do have Logic Express somewhere, so I'll keep an eye out for AUs (if anyone can recommend one I would be grateful).
I shall have to take another look at Xpand! I remember dismissing it when it first arrived with PT (PT7 I think) but now I think about it, it was probably because the sounds were just what I now need!
:bouncy:
Thanks guys, I'll update the thread when I get back to the studio.
Freuman
Post by BenLD »
Quicktime has a built in crappy GM synthesizer but I'm not sure if you can access it in Pro Tools
In Logic you can access it using the DLS music device under AU Instruments>Apple>DLS Music Device, but as far as I can tell you can only change sounds using program changes (like the ones you find embedded in GM midi files) - might be worth a bit more investigation
EDIT - you should be able to access it via Garageband if you don't have Logic
Ben
BenLD
Posts: 155 Joined: Wed Jun 08, 2005 12:00 am
Post by Freuman »
Desmond - How would I get these to play in PT?
Freuman
Post by Richie Royale »
Probably no use to you, but the GM player in Cubase SX is truly awful sounding! The piano and string instruments all sound the same. :headbang:
Richie Royale
Posts: 4551 Joined: Tue Sep 12, 2006 12:00 am Location: Bristol, England.
Post by onesecondglance »
any chance of getting a soundfont to play in PT? plenty of samplers (e.g. Kontakt etc.) can interpret the .sf2 format.
there's TONS of really terribly dated GM sets for free as soundfonts...
onesecondglance
Posts: 1248 Joined: Wed Jan 02, 2008 12:00 am
Post by keeno »
This sounds like a brilliant project... Post an audio clip fo the results!
Not often I see enquiries for crap sounds!!
keeno
Posts: 115 Joined: Fri Sep 07, 2007 12:00 am
Post by Bob Moose »
wow it reminds me of track 8 on Autechre's "EP7" album ;)
for sure GM is you friend here (or XG?)
Bob Moose
Posts: 694 Joined: Thu Jan 17, 2008 12:00 am
Post by Tomás Mulcahy »
XPand is actually quite good sounding!
I would go to a secondhand shop and pick up a Yamaha home keyboard for under 100. The Yamaha PCMs are a bit cheesier than the Casios :)
It'd make a nice pressie for your niece/ nephew later.
Tomás Mulcahy
Posts: 3007 Joined: Wed Apr 25, 2001 12:00 am Location: Cork, Ireland.
Post by forumuser732935 »
Tomás Mulcahy wrote:It'd make a nice pressie for your niece/ nephew later.
Just be kind to him, and combine it with a halfway decent multi-effects pedal too. :)
As for the nastiest, cheesiest GM presets you'll ever find, you could do worse than look up Bree Gorton's soundfonts. But they are amazing for the 50k or so they take up...
forumuser732935
Posts: 61 Joined: Wed Dec 14, 2005 12:00 am
Post by wardo »
for moments like this i turn to my trusty casio sa-1 100 sound tonebank
kontakt 3 has some casio sounds if you've got that
wardo
Posts: 247 Joined: Thu Mar 16, 2006 12:00 am
Post by Freuman »
No Kontakt3, no kontakt at all... :frown:
Probably a good investment, but a bit of an expensive whim, but that's the sort of thing.
I always thought hardware would be the easiest way to go. (due to Digidesign's distaste for freebies/cheap software :roll: )
I tried the DLS, but due to my lack of knowledge (me thinks), I couldn't get anything to play in PT.
It is working in Logic though, so I think I have a (cross platform) solution..
Freuman
Post by wardo »
Freuman wrote:
Looks like hardware is the easiest way to go.
hopefully you should be able to find an old casiotone or similar cheap 2nd hand.
the rapman is well worth looking out for but might be more pricey as i suspect they've become collectible :headbang:
hilarious really...should be good for comedy!
i can waste a whole afternoon with mine and the space echo :lol:
wardo
Post by sonics »
I've got a little white Yamaha sound module thingy here, a bit like the famous Roland MT-32. I was going to put in on ebay, but didn't think it was worth it. Properly programmed, it can actually produce music, but feed it some un-massaged MIDI files and stand back! :lol:
I did at one point need to audition MIDI files, and used that before turning to the Roland Sound Canvas VST plugin, and these days I'd use Hypersonic if I ever had to do the same thing again.
sonics
Post by Chevytraveller »
I have an original Casio VL1 which I could lend to the cause.. drop me a PM and we can work something out :lol:
for those of you too young to know what this is
Casio Vl-1
Chevytraveller
Posts: 948 Joined: Sat May 13, 2000 12:00 am Location: Hastings
Soft: MBP 15", X-Station, LogicX, Mainstage 3, Korg legacy, Diva, Alchemy, FabFilter.
Hard: Mostly now all for sale.. but Akai MPC Live, Tasty Chips Gr-1, Roland Promars, AS Telemark,  Eurocrack disease
Post by danabnormal »
Chevytraveller wrote:I have an original Casio VL1 which I could lend to the cause.. drop me a PM and we can work something out :lol:
Casio Vl-1
Was gonna mention this, a classic!
There is a VST of it somewhere too. Meeeeemoriiiiieeeeees! :lol:
danabnormal
Posts: 24 Joined: Mon Jul 14, 2008 12:00 am
Post by TheReson8or »
You could always sample from the pop idol/x factor backing tracks! :D
TheReson8or
Posts: 1569 Joined: Fri Apr 25, 2008 12:00 am Location: derbyshire uk
My head hurts!
Post by Hewesy »
Casio Vl-1
I had the one before that, without the fancy LCD screen :D
The PT-1!
Sounded nothing like flute etc, but strangely compelling when your 12...
Hewesy
Hewesy
Posts: 866 Joined: Tue Oct 19, 2004 12:00 am
Post by ceejay »
danabnormal wrote:There is a VST of it somewhere too. Meeeeemoriiiiieeeeees! :lol:
If you REALLY want the VST :lol: here it is ...VL-1 VSTi
ceejay
Posts: 162 Joined: Thu Apr 17, 2003 12:00 am Location: somewhere in Oz
Post by Freuman »
Just to update, I bought an old Yamaha PSS-30 for lead lines:
Amazingly bad!
I am mainly using Apple DLM sounds through logic express.
(Still not found any way of using these in Pro Tools...)
:frown:
Freuman
