Rycote Invision
Rycote Invision
Post by Andi »
Got my subscriber Rycote Invision USM this morning - (thanks Luci) - and I don't know whether to use it to hold a mic or to frame it and hang it on the wall; it's a stunning bit of design and engineering. It actually makes me feel good to know that someone out there can still be bothered to do a job this right.
Gush
:beamup:
Andi
Posts: 672 Joined: Thu Sep 02, 2004 12:00 am Location: Berkshire, UK
A
Re: Rycote Invision
Post by Steve Hill »
Agreed. Much as I love their mics, I really think Neumann, Sennheiser etc might as well cease production of their own shockmounts right now. £250 for a U87 shockmount? £240 for an MKH-series shockmount?
I know there's some engineering in there, but that's true of Rycote's offerings too.
So that's an English defeat for Germany then.
Steve Hill
Posts: 3206 Joined: Tue Jan 07, 2003 12:00 am
Re: Rycote Invision
Post by Andi »
Steve Hill wrote: So that's an English defeat for Germany then.
As unlikely as that may seem at the moment.
A. :beamup:
Andi
A
Re: Rycote Invision
Post by John Willett »
Steve Hill wrote:Agreed. Much as I love their mics, I really think Neumann, Sennheiser etc might as well cease production of their own shockmounts right now. £250 for a U87 shockmount? £240 for an MKH-series shockmount?
:D I have actually ditched all my Neumann and Sennheiser mounts and replaced them all with Rycotes.
The Rycotes *are* actually technically better. :D
John Willett
Posts: 7297 Joined: Tue Mar 07, 2000 12:00 am Location: Oxfordshire UK
Re: Rycote Invision
A. :beamup:
Ahhhh... on a day like today I hate to say this, but I must...
If the market is paying a lot more for an inferior German product, they must be making more money. A moral victory for the English, but the Germans are laughing all the way to the bank :roll:
Posts: 13298 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
Re: Rycote Invision
I've got a couple of lyre mounts for my NT5/55. I always feel as if I'm going to break them trying to get the mic's in there, because it needs some rough treatment, but they're tougher than they look. Clever design indeed.
Does anyone know which mount would take a Senny MD441?
Posts: 21437 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Re: Rycote Invision
The Elf wrote:Does anyone know which mount would take a Senny MD441?
Unfortunately, none of the InVision mounts are suitable for the MD441.
It would physically fit in a USM, but the axis of operation is completely wrong (horizontal instead of vertical) and the performance would therefore be rather inferior.
Hugh
Posts: 43693 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Re: Rycote Invision
Thanks Hugh. I suspected that might be the case. I’ve just ordered my second 441 clip in 6 months. They break so easily. It’s the worst mic mount in my collection, followed closely by the MD421 – fine when it’s in place but every time you try to move the mic it unclips – worse on the Mk2, ironically. :crazy:
Re: Rycote Invision
Post by Andi »
I just finished a recording session, and whilst the mic was up I did a few tests with the Rycote and the orignal mount for my RED5 RV15 LDC. The tests were not particularly rigorous - I ran a Cubase session with 2 tracks, one for each mount. I recorded the room, me walking around the room, and me tapping the stand. Accepting that this is highly non-rigorous - I did each one 5 times. I then topped and tailed the audio and ran a spectral anayser against sections of it. Again, accepting the lack of scientific rigour - the recordings done with the Rycote mount were between 2 and 5 dB lower in the lower frequencies (I'm seeing peaks at around 20Hz and 70Hz in each case)across the board. If anyone with a matched pair of mics care to do something similar I'd love to know how that works out?
Andi
A
Re: Rycote Invision
That sounds roughly in the right ball park. It depends on the nature of the mic you're using -- some have a basic form of shock mount internally and those obviously don't benefit quite as much from the USM -- and the stiffness and weight of the mic cable (and the way you have dressed it.
But something between 5 and 10dB reduction in mechanical vibration noise below 100Hz is fairly typical.
Hugh
Re: Rycote Invision
Post by Andi »
The RV15 is a tube mic and the cable is a bit on the stiff side. I have it looped with about a 2-3 " radius and then tucked into the clip - no tail. That's probably worth another dB or so in itself. What really pleases me is how easily the mount grips the mic and how easily it stays in place without drooping - someone employed a good materials scientist. The light weight helps with stand stability when the mics out on a boom too.
A.
Andi
A
Re: Rycote Invision
Andi wrote:... someone employed a good materials scientist.
Rycote employs very good engineers who know how to design, test, develop and production-engineer their products.
Unlike the majority of shockmounts on the market, the Rycote InVision stuff is actually designed to work, rather than just be cheap to make, and the designs really are all thoroughly tested and optimised to make sure they do what they're supposed to.
It's quite refreshing isn't it? ;)
hugh
Re: Rycote Invision
hugh
And when they have done all that they throw them at people like Hugh and me to see if we can break them :D
And to see if we can find anything wrong using them in a real life recording situation.
And any comments we pass back are taken on board for the final design.
They are good people with great engineering that listen to users - and my design for an MS lyre mount (designed by using existing Rycote parts put together in a different way) has now been put into productin by Rycote as a standard product. :bouncy:
John Willett
Re: Rycote Invision
Post by ROLO46 »
My STC 4033A weighs 3 lbs
Its been siting in a USM for 6 months now
Held only by those grippy little pads on a tapered mic neck.
Quite amazing.
Will look out for the Willet MSer next time I'm in Slad RD. :angel:
ROLO46
Posts: 881 Joined: Thu Nov 29, 2007 12:00 am
Re: Rycote Invision
ROLO46 wrote: Will look out for the Willett MSer next time I'm in Slad RD. :angel:
Didn't you see it the last time you were there on the Open Day - it was on display?
By the way - I am told Rycote will have another Open Day on the 3rd September for those who missed the last one - Hugh or I will post more news when we get it.
John Willett
Re: Rycote Invision
John Willett wrote:By the way - I am told Rycote will have another Open Day on the 3rd September for those who missed the last one - Hugh or I will post more news when we get it.
That's good news. Hopefully I can make the next one.
