Best clip on mics for toms
Hi all
firstly apologies if this has been covered elsewhere, I have tried searching the forum without success!
I have an old AKG drum mic set, including a D112, 2 x C1000s and some clip on mics for toms and snare. Only ever use the D112 on a drum kit as I have better alternatives. The clip mics (I forget the model no., they're at the studio right now so I cannot check) sound horrible - really wonky response (sort of thin and smacky without much body).
My question: what are the best clip on mic for toms? I have used SM57s in the past but am sick of playing tetrus with mic stands, cymbal stands etc and don't have the space!
What are you using in your toms?
Cheers
Cheers
- Ex is Moor
Poster - Posts: 17 Joined: Wed Nov 27, 2002 12:00 am
Re: Best clip on mics for toms
You could try something like a Sennheiser MZH504 Drum Mic Clip with an SM57.
- andy cross
Regular -
Posts: 192 Joined: Tue Apr 22, 2003 12:00 am
a good start.really good littlt mics and clips, slightly to my surprise!
- Guy Johnson
Posts: 1336 Joined: Fri May 02, 2003 12:00 am
This is my few words.
- Bob Bickerton
Longtime Poster -
Posts: 5639 Joined: Fri Dec 20, 2002 12:00 am
+1 for the D2, and when you master them the audix clips are quite good...but they do need practise. Dave
- TheReson8or
Frequent Poster - Posts: 1569 Joined: Fri Apr 25, 2008 12:00 am Location: derbyshire uk
My head hurts!
Thanks all for your tips so far!
- Ex is Moor
I'm going to be that annoying person
I've never liked clip on mics of any sort for a couple of reasons.
1. I've never heard one that did a better job on toms than some of the more obvious choices. Eg 421's
2. Attaching things to the rim of a drum affects it.
3. If you want to tune the drum it becomes a pain to take the mic off between ever other take.
4. The tom mic stands are hardly ever difficult from a position point of view. It's always that fiddly area around the hat, snare and left crash stands, where you're trying to get snare top and bottom stands to fit that causes most of the problems.
5. Almost all these designs affect how freely you can position the mic.
If your primary goal is results in a studio setting, I'd go for a more traditional approach. But it's a personal thing, and I appreciate that you've said you don't want to do that. Sorry for being 'that guy'.
Jack
Jack
- Jack Ruston
Posts: 3847 Joined: Wed Dec 21, 2005 12:00 am
For Studio? Then I'd go with what Jack said. Clip ons are all a bit of a compromise. I've never had a difficulty in positioning short stands to get good tom mic positions, but some kits can be difficult I agree.
However, in my live sound experience, in no particular order:
Beyerdynamic Opus
Shure Beta 98a
Audix D2
Sennhiser E604 or E904
All of which are great live. Never used them in a studio setting.
Beyerdynamic Opus
Shure Beta 98a
Audix D2
- Dave Rowles
Posts: 1589 Joined: Thu Feb 28, 2008 12:00 am
http://www.manninmusic.com Teacher - Isle of Man
http://www.manninmusic.shop Music Shop - Isle of Man
https://www.facebook.com/mannin.sound - PA Hire/Sound Engineer - Isle of Man
Hi, I should add that mic stands are preferable to clip ons but if you have so little space,as I have , then they are a necessity.Dave
- TheReson8or
My head hurts!
Short stands with round bases take up hardly any room and give you a much better choice of mics and positions. I like the Sennheiser 504's but I rarely use the clips as they just don't let me position the mics where they sound best.
James.
James.
Posts: 16990 Joined: Mon Sep 10, 2001 12:00 am
Got D2s myself. The sound on toms is nice. But they're supercardioid, and I've found they seem to cop a fair bit of cymbal spill from that rear lobe, with a typical rock drumkit setup. Suitably gated they're good, but without gates there's a lot of unwanted sizzle.
I was assuming clip-ons for live, in the studio I'd usually prefer 'normal' mics.
D2s etc. are very good, as long as you've got a huge live budget, and a good point about the hypercardioid pattern ... but in most live situations, I'd rather spend on monitors, in-fill speakers, vocal mics, desk — bearing in mind that...
1) the difference between the best clip-ons and the budget Thomann ones in almost all gigs is minimal
2) these mics are very near drum-sticks ... and I'd rather have good cheap mics for drummers to bash!
Hope that all makes sense this early in the morning.
- Guy Johnson
Thanks for all the helpful comments. I was thinking for live situation (sorry didn't make this clear) but ideally would get some studio use too. Think I may opt for the t bone set for now and upgrade to D2s and shorts stands for the studio when I have the budget
thanks again!
thanks again!
- Ex is Moor
