Chrome plating (or similar effect)
Post by jellyjim »
Hello
I want to get some small parts chrome plated for a custom build. I've had a good Google but most places seem uninterested (presumably because I'm asking for a quote for a few bits and pieces rather than 10,000 bathroom fittings) or have been prohibitively high. I appreciate it's labour intensive but £200 for something the size of my thumb? You have acquired a giraffe sir.
Any recommendations? I would also consider other techniques that give a good chrome effect such as vacuum metallising and I've read that chrome paint has come on leaps and bounds in recent years but at close to £100 for primer, paint and hardener and the likely fact I won't have the skills to prepare the part properly (which I understand is the critical aspect of a chrome finish) then I may as well not do it myself anyway.
Jim
jellyjim
Posts: 1752 Joined: Wed May 15, 2002 12:00 am Location: uk
Re: Chrome plating (or similar effect)
There are plenty of decent, local, metal plating companies. Check your local Yellow Pages for Metal Platers or Metal Finishers. And ask in your local car and motorcycle workshops too, especially those who specialise in customs and restorations as they need to get things chrome plated often.
A little searching will find you somewhere local, and you will find that it should be a lot cheaper than the paints you've been looking at. The refinishers/platers will put your parts in the tank with a number of other orders which keeps the price down.
You will need to talk to them and take advice. The plating process varies depending on the base metal you are plating and the finish you require. Some combinations require an intermediate metal to be plated.
And if anyone is interested in experimenting, it doesn't have to be chrome. You can plate with zinc, copper, nickel, and many other metals too. If you are interested in gold plating be aware that the price varies a great deal depending on how thick the plating is. In the past gold plate was typically 50 microns and was long lasting, but modern gold plate can be as thin as 10-15 microns (which keeps it affordable) and can wear very quickly.
Hope that helps.
Posts: 13115 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
Is it about a bicycle?
Post by Tony Raven »
Been years since I've done small-scale stuff, but let's see what's still rattling round my skull.
Actual "hard" chrome plating is largely a thing of the past, something about cyanide compounds. But you can get rather good effects DIY, for not horribly much cost. Here's a fairly typical kit, for "Copy Chrome":
http://www.micromark.com/Plug-N-Plate-Copy-Chrome-Plating-Kit,8327.html
Caswell is more lifestyle than hobby, but contains much reliable info:
http://www.caswellplating.com/kits/index.html
Their "Triple Chrome" systems begin at $599; while it still produces nasty fumes, it's nothing so bad as cyanide.
Just enter metal plating kits into your search engine for more options.
Tony Raven
Posts: 157 Joined: Sun Nov 15, 2009 12:00 am
resident troublemaker, http://forum.frugalguitarist.com/
Post by jellyjim »
Thanks Andy, I didn't know to search under those keywords, I will.
Thanks Tony, those DIY solutions look interesting.
jellyjim
Post by TheChorltonWheelie »
jellyjim wrote:I want to get some small parts chrome plated for a custom build.
I'd go with Andy, send it to a specialist firm - I had some brightwork down for a restored Peavey, pickup covers, truss rod cover, metal scratchplate, and from memory it was about £30 all in and the finish was, and still is superb. I can't remember specifically what the issue was, but when they recoated them they pointed out why a specific process was required, rather than the one I suggested, so you're also paying for their years of knowledge too.
TheChorltonWheelie
Posts: 1079 Joined: Tue Sep 22, 2009 12:00 am
Post by drharker »
If you need any type of plating, I think you should visit this site: en.cromkontakt.hu
The Cromkontakt made me some plating on my equipment, and that was very good.
drharker
Posts: 1 Joined: Wed Jan 17, 2018 12:51 pm
http://www.nmpltd.co.uk/
Give them a bell ^ About as central for England as you will get?
Posts: 18511 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
The original post was in May 2011, so it's probably a bit late to be posting more info now. :)
Posts: 18678 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
I suspect the thread was revived by a Hungarian spammer, but giving the benefit of doubt it it might be a genuine post intended to be helpful. Drharker hasn't made any other posts so far, so we'll see...
Posts: 42796 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
The name seems familiar though - maybe on another post which got deleted because it looked like a spammer?
I approved the post, but had my doubts. But as he is a new member his posts have to be approved before appearing in the forums. So if he had made a spam post it would have been disapproved at that point and not appeared.
The name is familiar? Have you reread Bram Stocker recently? ;)
Wonks wrote:The name seems familiar though
Fangs for the memory? :beamup:
Posts: 22102 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
