zenguitar wrote:No need to feel guilty Si, since I joined the forums tracking down pdf's has become a hobby of mine
Well - I suppose everybody's got to have one...
The schematic isn't totally clear, it appears that the black and white connections from the bridge pickup are linked to the same terminal on the 5-way.
No, it's not. It's not even particularly clear which pickup is which, but from checking how they look on the guitar, I'd say the top one is the neck. So that's the bridge pickup that has the black and white going to the 5th connection (l-r) of the switch. My guess is that this connection gets earthed in the 4th position, meaning only the coil that has its other end to hot is voiced. Otherwise, no connection puts both bridge coils in series for full humbucking.
Standard DiMarzio wiring has the north polarity coil with red and black and the south polarity coil with green and white. Red and white hot, green and black ground.
Actually, there's a really handy
Humbucker Colour Code Conversion Chart over at the Bare Knuckle website (sorry if I've spoilt your fun by sniffing that out for you!). Interesting to note that none of the major pickup manufacturers can agree on a simple colour code!
The wiring diagram seems to show the 4th position with the two inner coils as series wired.
Definitely in parallel, I think. It has that hollow Strat tone, so it has to be, right? Like you say the diagram's a bit of a nightmare to follow...
To keep it humbucking in that position you would need to rotate one of the pick-ups from the standard Gibson arrangement. And that would also retain the N-S N-S pole arrangement from the standard pick-ups. So, with a little further thought, that would be how I would go. I wouldn't worry overmuch about the difference between the slug and screw coils. Give it a try and see how you like the sounds.
I think the only thing that puts me off with that is the aesthetic of it. When I started playing - way back when - I used to think that LPs looked "boss-eyed", now it seems the norm. I've sent an email to the guys at Bare Knuckle (who've been great so far, BTW), checking that rotating that pickup won't affect the sound too much.
As for the paint in the cavities, it's probably not conductive. Generally, the bodies are machined fully and then move on to the spray booth for painting. But if you want to check, just use a multimeter to check the paint for conductivity.
D'oh! Yeah, that would work, wouldn't it? Especially considering that I've just scored a continuity meter!
For the neatest possible job I would use a router with a template following bit (with a top bearing). Use that to follow the edge of the existing cavity and you can control the depth very accurately.
How does that all sound?
Terrifying! I was going to go for a much more DIY approach! The way the pickup cavities currently are, they've got a stepped bottom to them: where the mounting tags sit is a good 5mm deeper than the bit that sits under the base-plate. There's a diagonal groove through this section to allow for the pickup's cable to be routed across the cavity if the pickup is mounted with the cable exit to the top (i.e. the traditional Gibson way).
My plan was to make a template of the pickup's footprint, mark in the position of the screw pole-pieces, then drop this into the cavity and use something like a bradawl to mark out the drilling spots. Then I was going to take a wood-bit that was just a tad wider than the screw-ends, stick a bit of insulating table round it a few mil from the end to mark my depth, and go at it with my black and decker!
I think I need only drill down to a depth of 5mm or so, so being super-perpendicular isn't going to be a massive requirement.
Also, as this is an Ibanez RG, with it's spring cavity and trem back-rout, there's not a whole lot of wood there to start with, and I'd like to keep as much as possible in order to give the pickups something to resonate with! Hence me wanting to make sure I get the orientation of my pickups right the first time, rather than have to go back in and drill some more holes at a later date.
Does that sound like a recipe for disaster?
Thanks,
Si
