Whilst some LDCs are edge-terminated, quite a lot of LDC have their capsules centre-terminated. You can compare both styles on the following page:
Centre or Edge Terminated
Now I understand that having a very thin diaphragm (some are only 6 microns) is a good thing for sensitivity, because the diaphragm has less mass and is less rigid - double win. However this surely must be wrecked by the heavy mounting and the wire attached - which must have thousands of times as much mass as the diaphragm. Or am I missing something?
If anyone has any technical knowledge and can explain, I'd be grateful
