I need some advice: I want to cut and solder my own guitar cable because I gig a lot and also regularly need cables of varying length so I might as well buy a reel and some jack plug ends.
Can you suggest where is good to buy roll of cable, and what to look for etc? I read ultrapure oxygen-free copper is a decent cheap basis to work from though that's only after 10 minutes of Googling so that might just be a given.
Where is good to buy the cable from, and the jack ends too? I'll probably be needing cables of around 2-3m each so a 10m or 20m spool of cable would be good to start off with.
Have you got any advice for me?
Eagerly awaiting your reply
Thanks!
