Attaching lighting to speaker stands/poles
Post by One Horse Town »
Hi
Is it possible to attach a t bar to a speaker stand or sub pole AND still use the speaker tops? I've seen these O ring clamps but they're only good for one light. I guess what I'm after is a mounting bracket incorporating a pass-through hole for the speaker stand but enabling it to be clamped thus holding the t bar. Is such a product available? Wouldn't be surprised if it wasn't as it would affect sales of lighting stands......an opportunity for someone nevertheless?
One Horse Town
Posts: 464 Joined: Sat Apr 04, 2009 12:00 am
Re: Attaching lighting to speaker stands/poles
Anyone?
One Horse Town
Post by dmills »
Depends on the stand, while I would not hesitate to do something involving a boom arm or two on a Doughty heavy duty stand with a load of weights on the base, doing the same on something lightweight could be a very bad idea.
Check the loading numbers for the stands you are using, then whistle appropriate bits up from Doughty or someone similar.
Regards, Dan.
dmills
Posts: 1533 Joined: Fri Aug 25, 2006 12:00 am Location: High Wycombe, UK
Thanks Dan
My speaker stands are K&M's with ring locks. Do I understand correctly that instead of a T bar I should try attaching a boom to the stand? If so, how would this be fitted? In the meantime I'll look at the Doughty site you recommeneded.
One Horse Town
Post by robare99 »
I attach lights to the fly points on my speakers, it works pretty good!
robare99
Posts: 207 Joined: Mon Feb 28, 2011 12:00 am
