4K Cubase
4K Cubase
Post by Gerhard Westphalen »
So the price of 4K seems to be coming down. Dell has a 28" 4K monitor for $700. I downloaded a 4K desktop screen shot with normal scaling to see how small things would look with 4K. My monitor is 27" so its not too far off from the Dell. When I full screened the image everything was tiny. I'm wondering if you guys think that using Cubase (or other DAWs) would work on this 28" monitor or if everything would be too tiny to see. I image that "aiming" the mouse would be difficult.
Gerhard Westphalen
Posts: 226 Joined: Sun Mar 21, 2010 12:00 am Location: Calgary, Canada
Re: 4K Cubase
Post by JeffJeff »
With regards to finding the mouse pointer, at least on Windows, you have various features available to you in the 'Mouse' Control Panel (Mouse control panel -> 'Pointer Options' tab):
  • 'Display pointer trails'
  • 'Show location of pointer when I press the CTRL key'
  • Enhance pointer precision
  • Adjust the speed at which it moves (slower is easier to be accurate with, but it'll take longer to get the pointer to where you want it)
  • Automatically move the pointer to the default button in a dialogue box (this one drives me mad!)
Also, in the 'Pointers' tab you can select different styles and sizes of mouse pointers.
JeffJeff
Posts: 63 Joined: Fri Jan 02, 2009 12:00 am Location: London (England!)
Don’t use apostrophes in plurals. It's not what they're for. Just add an S on its own!
Re: 4K Cubase
JeffJeff wrote:With regards to finding the mouse pointer, at least on Windows, you have various features available to you in the 'Mouse' Control Panel (Mouse control panel -> 'Pointer Options' tab):
I don't think the problem would be finding the mouse I think it would be actually getting it over buttons like the little buttons in the Cubase mixer. You could slow it down but then it would take ages to get your mouse across the screen, especially if you had multiple monitors.
Gerhard Westphalen
Re: 4K Cubase
Post by JeffJeff »
Gerhard Westphalen wrote:You could slow it down but then it would take ages to get your mouse across the screen, especially if you had multiple monitors.
Agreed (and I did acknowledge that exact issue). Not sure what the answer is...especially as I run Cubase on my laptop so I'm nowhere close to the kind of display you're talking about! :)
JeffJeff
Re: 4K Cubase
Post by G-Doubleyou »
Do you have the main ingredient? A video card that can output 4K!
8-)
G-Doubleyou
Posts: 972 Joined: Fri Feb 10, 2006 12:00 am
G-Dub Studio G-fx 2011 15inch 2.0GHz quad-core i7 Macbook Pro, LPX 10.3.2
2.3 GHz quad-core i7 Mini
Re: 4K Cubase
Post by Scramble »
If you're worrying about surviving in LA soon then forget about spending lots of money on expensive graphics systems that you don't really need. Save your pennies.
Scramble
Posts: 2431 Joined: Wed Sep 11, 2002 12:00 am
Re: 4K Cubase
I believe most displayports and HDMI 1.4 can output 4K so I don't think it would be an issue
Gerhard Westphalen
Re: 4K Cubase
Scramble wrote:If you're worrying about surviving in LA soon then forget about spending lots of money on expensive graphics systems that you don't really need. Save your pennies.
I'm not going to spend $700 on a monitor! I'm just saying that the price has come down considerably and will hopefully continue to drop. Just seeing if you guys think it would be usable in a studio. I believe this is similar to when SSDs were starting to drop in price. Nowadays everybody's advice is get SSDs if you can afford them and so hopefully it will be like that with 4K not too far into the future.
Gerhard Westphalen
Re: 4K Cubase
Post by Pete Kaine »
We've played around with the 28" screens, honestly I think you'd want real estate for a 4K display. You can resize icons and text within windows to make it more usable, but the first time you load up a plug in that doesn't support that fully, you'll be struggling. Still, give it a few years and you'll be seeing it break the mainstream more and the prices tumble, the are already some 48"+ TV screens under a grand that seem a bit more suitable for this sort of work.
Pete Kaine
Posts: 3217 Joined: Thu Jul 10, 2003 12:00 am Location: Manchester
