Best DAW to use with multiple synths
Post by steve_cromey »
Any suggestions for which DAW I should go for - I have a korg kronos (master) roland g8 (slave) plus roland tr8 and tr3 and want to record them (sometimes simultaneously) into a daw using a PC. Thanks
steve_cromey
Posts: 3 Joined: Thu Nov 18, 2004 12:00 am
Re: Best DAW to use with multiple synths
Post by mhaigh »
any standard DAW will be fine to record multi-track audio and midi, providing you have the appropriate soundcard.
mhaigh
Posts: 451 Joined: Wed Nov 14, 2007 12:00 am Location: Hockley, Essex
Post by IAA »
You could use your Kronos if you just want to try out some ideas before embarking on a full DAW learning curve, plug-in lust, latency etc etc.
I use Logic but often sketch on my Kronos and record some other stuff on it too and its pretty neat - if something feels good I then export to Logic.
But to be honest for simple things - for me anyway - the K is v capable.
Depends I suppose where you want to get to.
Ian
IAA
Posts: 1621 Joined: Fri Dec 28, 2007 12:00 am Location: York
Cheers Ian
I really enjoy sequencing with the Kronos especially with the Karma options (arpeggiator on steroids) - I also sequence on the Roland G8 (mainly for sampling) and have both playing in sync - now that I trigger other stuff with them I want to capture full compositions using a DAW - have just been browsing through the free PC software posts and will give them a whirl before committing to buying ... My concerns are around being able to record multiple synths at the same time ...
steve_cromey
Post by muzines »
steve_cromey wrote:My concerns are around being able to record multiple synths at the same time ...
Record as audio or record as MIDI?
muzines
Hi Desmond - aim is to record audio from 4 different sources (3 synths and 1 drum machine)
steve_cromey
Post by Scramble »
As mhaigh said, any DAW can do this as long as you have the appropriate audio interface that has enough input channels.
However, you won't be able to record all the synths from their digital outputs (assuming they all have digital outputs), because typically audio interfaces only have one S/PDIF digital input, and anyway you run into clocking problems trying to record more than one digital input at a time. But if you are happy to take the signals from the analog outputs of the synths into the interface then no problem (and you could record one synth digitally in that case and the rest analog).
Alternatively you can record track-by-track, which would allow you to record each purely digitally, but there's no great advantage to recording the digital output instead of the analog as long as you don't have any buzzing or excess hiss, etc. on the analog channels.
Scramble
Posts: 2431 Joined: Wed Sep 11, 2002 12:00 am
The ability to record multiple simultaneous sources is a feature of the audio interface you choose. Pretty much all decent DAWs (Cubase, Logic, Pro Tools, Reaper, etc) will do the job - MIDI or audio.
Posts: 21434 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by Dynamic Mike »
Some freeware DAW's & some Lite versions restrict the number of simultaneous inputs you can access, so you might need to check before you buy. If you just want to record a live performance & don't need to tweak it afterwards, then a cheap basic 8:2 mixer might be all you need.
Dynamic Mike
Posts: 5291 Joined: Sun Dec 31, 2006 12:00 am
Why do bad things mostly seem to happen to people who light up a room when they enter it?
If you want to use the USB audio options on the TR8 and TR3 you need to check that they can both be used at the same time with ASIO. If Roland have been sensible they will have designed the drivers to appear as a single multichannel device. If Roland haven't been sensible and they require separate drivers you will be limited in your choice of DAW to those that can use alternatives to ASIO. Since Roland own Cakewalk, they will almost certainly work with it while Reaper is another DAW that can use multiple devices with different drivers.
Posts: 16988 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by mhaigh »
erm...Roland don't own Cakewalk...
mhaigh
Post by Scramble »
True, but they only sold it 3 1/2 months ago.
Scramble
Post by hollowsun »
mhaigh wrote:erm...Roland don't own Cakewalk...
I think you'll find they do...
Roland acquired a majority stake in Cakewalk in early 2008, they jointly created a new ‘Cakewalk by Roland’ brand
The may not 'own' it but as a major stakeholder, they pretty much control the shots!.
Unless something has changed.
hollowsun
Posts: 2036 Joined: Thu Jan 20, 2005 12:00 am Location: Cowbridge, South Wales
Website / Music Lab Machines / Blog
Post by hollowsun »
Scramble wrote:True, but they only sold it 3 1/2 months ago.
Aha!
hollowsun
Post by Scramble »
Did you forget all the ruckus recently over the fact that it was useless Gibson who bought Cakewalk?
Scramble
Post by hollowsun »
Forget? I didn't even know! :lol:
hollowsun
I had a funny feeling when I was typing that my info was out of date but didn't have time to check...
Post by Scramble »
Here.
Scramble
