Can't figure out WHICH Sylenth 1 Bank is loaded
Post by johnny28xh »
as the title says...
after I load a previously saved project in my DAW and I go to the track which has Sylenth 1 VST on it,...
I see the preset in use,... but I DON'T see the soundbank that that preset belongs to.
If I want to write down that preset path , to memorise it, how can I do it ?
(and exporting the bank or preset isn't a desired answer , no sense in doubling the preset on my HDD if it's already present) - there has to be a way to tell which soundbank is loaded !
I searched and searched and no tutorial shows this; it isn't specified in the Sylenth 1 manual either.
johnny28xh
Posts: 2 Joined: Sun Aug 03, 2014 12:00 am
Re: Can't figure out WHICH Sylenth 1 Bank is loaded
Post by robinv »
Does this help at all?
http://www.lennardigital.com/support/soundbanks.php
Lots of people seem to be having similar problems with presets not loading or losing soundbanks.
robinv
Posts: 602 Joined: Tue Aug 31, 2004 12:00 am
Molten Music Technology - Synths, modular, software, Surface and weird noises.
https://linktr.ee/moltenmodular
Post by muzines »
johnny28xh wrote:there has to be a way to tell which soundbank is loaded !
It it doesn't indicate which bank is loaded, or display it anywhere, or preserve the name on a save/export operation, then you're probably out of luck.
You could do a manual spreadsheet/etc of which sounds are in which bank (so you can look them up if necessary), or export them individually to your host to stop using banks at all if it supports that...
muzines
robinv wrote:Does this help at all?
Thank you for your input robiny,.. but it didn't help; I already knew what was stated there.
Thanks for the idea, desmond; I might take it into consideration and apply it if I can't find a workaround.
johnny28xh
Post by chris... »
johnny28xh wrote:If I want to write down that preset path , to memorise it
Sorry if obvious, but your DAW will memorise it for you, when you save your song.
Of course, there may be other situations, like making a new song where you want to include the same sound.
chris...
Posts: 2720 Joined: Wed Mar 12, 2003 12:00 am Location: Sunny Glasgow
