Digital piano - do you record bone dry, and add fx later?
Post by alexis »
Hi - I read recently an opinion that it's best to do just what the title of this post says - record (in this case from my Yamaha Motif) bone dry, and add the reverb, compression, chorus, etc., later. The idea was to not be limited by the effects built into the chosen patch.
That makes sense in a way to me, analagous to recording a vocal dry and enhancing later. But I've not heard of people doing that before with digital pianos, so I wonder if maybe it's not common to do that for some good reason or other?
Thanks for any thoughts :-)
alexis
Posts: 5258 Joined: Fri Jan 10, 2003 12:00 am Location: Hampton Roads, Virginia, USA
Home of the The SLUM Tapes (Shoulda Left Un-Mixed), mangled using Cubase Pro 14; W10 64 bit on Intel i5-4570 3.2GHz,16GB RAM;Steinberg UR28M interface; Juno DS88; UAD2 Solo/Native; Revoice Pro
Re: Digital piano - do you record bone dry, and add fx later?
Post by Scramble »
Yes, it is common, especially with the reverb, although with the chorus etc. some people prefer to just go with the sound they liked there and then (to save endless faffing about with FX later).
Scramble
Posts: 2431 Joined: Wed Sep 11, 2002 12:00 am
Post by BJG145 »
...yeah, same with anything; recording dry gives you more flexibility later, but recording with FX saves hassle and may also affect how you play.
Posts: 7907 Joined: Sat Aug 06, 2005 12:00 am Location: UK
Post by Exalted Wombat »
There's two sorts of effects, those that define the sound of the instrument and those that define its place in the mix. Assuming the piano part is being PLAYED, i.e. not constructed step-time in a sequencer, you'll get a better result by letting the musician hear the sound he'll be making.
For an extreme example, imagine asking a guitarist to play "Shaft" without the wah pedal, saying "we'll put that on later!" :-)
Exalted Wombat
Posts: 5843 Joined: Sat Feb 06, 2010 12:00 am Location: London UK
Post by grab »
If you record the MIDI as well, then you have more options. The digital pianos I've had experience of, you can send the MIDI back to the piano to get out exactly what was played, which might let you do some patch tweakage. Or you can use a PC-based instrument. And you have the option of twiddling the notes themselves if necessary.
grab
Posts: 2420 Joined: Sun Jul 08, 2007 12:00 am Location: Cambridge, UK
Post by damoore »
As well as reverb, chorus, etc, a big one is resonance. If you keep the MIDI, you can change this later too (if your VST or instrument supports that), but it has a big impact on the playing style, and especially on pedaling.
damoore
Posts: 981 Joined: Sun Jul 05, 2009 12:00 am Location: New Hampshire
Post by CS70 »
The more I record stuff, the more I find myself trying to capture the sound I want there and then. No experience with keyboards, but makes it so much easier to make the song sound like I have it in my head..
Posts: 7799 Joined: Mon Nov 26, 2012 12:00 am Location: Oslo, Norway
Post by alexis »
Thank you everybody for your helpful and thought-provoking answers!
I have adjusted programmable parameters on my Motif to create different sounds for live play, for organs and such. But for some reason when it came to the acoustic piano, for some reason it's never occurred to me to change "that" sound.
I'll keep an open ear for any changes that might be nice to make, based on your comments. I certainly won't feel forced to just because I can!
Thanks again -
alexis
Post by TheChorltonWheelie »
alexis wrote:Hi - I read recently an opinion that it's best to do just what the title of this post says - record (in this case from my Yamaha Motif) bone dry, and add the reverb, compression, chorus, etc., later. The idea was to not be limited by the effects built into the chosen patch.
That's exactly how I do it these days, try this: record a patch, with effects, and without, then mix them both into your track. How often do you actually hear the reverb/chorus in the effected instrument, and how much more defined does the unaffected instrument sound.
I've noticed how little effects something needs in the mix, so I tackle the job from the perspective of only adding what I can hear, rather than just starting with the default effected patch and then trying to squeeze it into my track.
TheChorltonWheelie
Posts: 1079 Joined: Tue Sep 22, 2009 12:00 am
Post by Barry Garlow »
CS70 wrote:The more I record stuff, the more I find myself trying to capture the sound I want there and then. No experience with keyboards, but makes it so much easier to make the song sound like I have it in my head..
Same here. In fact when recording the keyboards (which here is a Korg SP-200) i run it out to fx, amp & speakers and mic up to taste.
It depends very much on what's to be achieved though. I mean we are usually looking for a very live sound where the music puts the listener "in the room" so to speak.
There's a million other sounds that might be better achieved DI and treatment or even down the bottom of the garden with the faeries :)
Depends what one is trying to achieve and probably moreover, what feels right.
Barry Garlow
Posts: 386 Joined: Tue Nov 26, 2013 12:00 am
