Anyway, I've been attempting to do some quad ambience recording (don't see much need in full 5.1 channels for background room tones / outdoor ambience etc tracks) using the following setup:
2 x Rode NT4s mounted facing away from each other in a blimp
Tascam DR680
First problem - noise level. The recordings I've got on the Tascam are noisy as HELL. I'm assuming this is due to the Tascam itself being a budget recorder with poor quality preamps - do other people have similiar experiences with this device? Or are Rode NT4s really noisy mics? Or perhaps running unsheilded stereo cables alongside two powered microphones potentially creating noise in the signal?
The recorder isn't such a huge problem as I have potentially access to much better stuff - 2 x Sound Devices 744 are available to me, and/or I could hire the SD 302 mic pre addon to turn one of them into a 4 channel recorder (lugging two 744s around then having to sync the recordings sounds like a faff).
The other issue I had is that while the front/rear separation is pretty spot on and folds down to stereo nicely, the actual stereo width isn't that great. The recording I have lack the broad left/right width that I experienced out there, and distant sounds almost completely mono.
I could probably fake them open more with plugins, but that's not ideal and potentially dangerous, so I guess I need to like at micing technique.
Any configurations I should consider that will give me the spaciousness I desire, but also be easily portable (I'll be driving or cycling around, setting up, recording for a bit then moving on to the next), suitable for outdoor (i.e. windy) use and wont involve spending hundreds upon hundreds in hiring costs?
Alternatively, anyone have experience using a Soundfield Surround or Holophone setup? Really interested in how well the work but can't find any examples of what they sound like.
Thanks!
