So, to see what the ART T8 transformers are doing I ran some tests on the T8 using a Zoom R24 and ART Pro Channel II as interfaces (of which I also took baseline measurements for reference).
The first graph is the T8 through the Zoom R24. The R24 is driving the T8 with an output impedance of 1 kOhm and is loading the T8 with an input impedance of 50 kOhms. The red lines are the R24, the blue lines are the T8 running through the R24 and the green line is the T8 frequency response with the R24 response removed (i.e. the difference in their frequency responses). The flat-ish lines are obviously the frequency responses, the dashed lines are the phase responses, and the downward sloping lines on the bottom half of the graph are THD.
Judging from the linear-ish THD response, the T8 appears to have, as expected, nothing-fancy steel transformers.
Blowing up the frequency responses (which I won't attach here) shows that the T8 is down almost 2dB at 20Hz and almost 0.8 dB at 20kHz.
The next graph is the T8 through the ART Pro Channel II as an interface (with the Zoom R24 still sending the test signal and receiving (loading) the T8 at the other end). The ART has an output impedance of 300 ohms feeding the T8 (still loaded down at 50 kOhms on the Zoom R24 receiving end).
Here you can see a marked improvement in the frequency response, phase response and THD of the T8. Blowing up and centering the T8 frequency response (the next graph) shows the frequency response is now in the +/- 0.3dB range from 20Hz-30kHz. Much better.
I also took a look at some specific THD readings at 50Hz, 100Hz and 1kHz (the next three graphs). These were the minimum THD points I found while adjusting the level through the T8.
At 50Hz the whole "system" had a THD of 0.32%. The graph below is the THD @ 50Hz of the ART PC II through the Zoom R24 without the T8 in line, for reference.
Subtracting the THD of the PC II & R24 gives an approximation of the T8's THD @ 50Hz and this approx. dB level as 0.32-0.028 = 0.292%. Doing the same thing at 100Hz and 1kHz gives 0.102% and -0.007%. I didn't adjust the level when switching the T8 in and out of the line, so I suspect the negative THD value for the T8 at 1 kHz is coming from the fact that there's a slight dB drop going into the Zoom R24 when the T8 is in line. So there's some error involved, but these are, I believe fairly reliable ideas of what the T8 is doing a least to 2 decimal places. As expected the transformer distortion is most odd (3rd and 5th) order.
T8 minimum THD values:
50Hz: 0.29%
100Hz: 0.10%
1kHz: N/A
T8 Frequency Response:
20Hz-30kHz, +/-0.3dB
Phase Error:
<20 degrees, 20Hz~50kHz
...at least at these test conditions.
To put that at least in some sense of context, the 1176LN and LA-2A are both spec'ed at more than 0.35% THD in their "healthy" operating ranges and the LA-2A frequency is similar to what the T8 was showing here (the 1176 drops a bit more). Not saying that inserting a T8 will make your chain sound like a 1176 in line or anything
I hope that helps someone who might be considering getting an ART T8, either for its intended purpose or as a transformer "colour box".
