hey guys..done a google search but still cant find this answer to my problem...
ive got the x32 setup so in the routing menu/home/aux to remap-card 1-4 so my main out from logic is coming out in on aux 1+2..and i have set a aux send in logic so i can use this as a headphone mix going out channel 3+4 in logic coming in on aux 3+4 on the desk.ive routed that to come out the aux3+4 outputs at the back of the x32.thats all cool and groovy..what i would like to do is route the talk back mic on the x32 to aux 3+4 as well...can this be done????
i should also mention this is my first digital desk so if you could explain in "bunny rabbit" terms
...must say this..its a pretty good desk...
just got my x32..how do i do this
- paul tha other
Frequent Poster - Posts: 831 Joined: Mon Sep 06, 2004 12:00 am Location: scotland
Re: just got my x32..how do i do this
yes but i can only route it to mixbus 1-16 or the main outs...can you route a mixbus to the aux 3+4
- paul tha other
You will need a spare MixBus or two. Send your returns to a spare bus (or two for stereo, select the mix bus, sends on faders and raise the aux faders for your remapped aux returns, I use spare channels for this as I configer my X32 Compact for 16/16 I/O through the X-USB card) then go to "routing>aux out" and select 'Aux3' as the output, make the 'Output Source' MixBusX. Now anything you send to MixBusX will come out of Aux 3. Repeat for Aux4 and that'll have your headphone mix going to aux 3&4.
Now go to Talk and route the TB to the one or two MixBusses you have chosen. Obviously you need to make sure the MB faders are up.
HTH
(I'm still learning stuff about my X32 and have learned some today, thanks).
HTH
Forum Aficionado - Posts: 22916 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Oh, and you can assign TalkBack to an aux in the 'aux out' tab on the 'routing' page but I don't think you can assign more than one source by that means.
I did post your question on the very helpful X32 forum (hence the extra info above), have a look here.
thanks sam....im at the read everything about 6 times..then it sets in ,then i can do it...its a ace board..its easy and complicated at the same time
- paul tha other
yas......got it....thanks for your help sam...im owe ya a pint
- paul tha other
You're welcome Paul. I'm also trying to learn about my X32 before I gig with it (I've done a couple but I've nothing in the book just now that can't be covered with the Mackie DL1608). Trying to find answers for others is easier to motivate for than a cold manual reading session
Recording (and playing) with a band tonight in the studio sung Reaper and the X32C so will progress.
It is indeed a fantastic desk for the money.
