Voiceover
Voiceover
Post by legitmik »
Afternoon folks.
Did a voiceover recording the other day with a girl who was extremely short sighted (has albinism) but has a fantastic speaking voice.
Because she's so short sighted, she had the script literally about 8-10 inches from her face at eye level. This caused all sorts of weird phasey / comb filtering sounds with the 414 at forehead height about 2 foot away pointing down towards her mouth.
Any (technical) suggestions on how to minimize the sound problems as I'd like to use her services on other voiceovers that are coming up.
Ta.
legitmik
Posts: 7 Joined: Fri Jan 23, 2004 12:00 am
"Your ideas are bigger than your budget..."
Re: Voiceover
Post by Freuman »
Ok, two practical solutions:
option 1.
Use a headset mic, (less quality, but keeps it out of the way)
option 2.
Use a different artist. She may have a great voice, but if you are getting bad results then the great voice wont matter.
hope this helps.
Freuman
Posts: 417 Joined: Tue Jun 10, 2008 12:00 am Location: Southend-On-Sea, Essex, UK
11011110110010101111 - 110000001111111111101110 - 101110101101 Hexadecimal binary coding anyone?
Re: Voiceover
Post by Daniel Drummond »
Print the lyrics really really big so she can see them from a distance. Different needs, different resources...
Daniel Drummond
Posts: 135 Joined: Sun May 07, 2006 12:00 am Location: Brazil
Re: Voiceover
Post by Rockrooms »
legitmik wrote:Afternoon folks.
Ta.
Is there any way that you could read a sentence at a time over the headphones and have her repeat that ? More editing for you, but if you really want to use the same artist worth a go ?
What about a flat panel / laptop or projection running a power point presentation using large fonts placed behind and above the mic ? Clunky, but again if you really want to use the same artist.
I'm currently in a project were most of the voice over talent are amateurs, one kept putting the script on his knees and read straight down to them, with similar effects to those you've described. Unfortunately it's all non English language so I'm not really able to do much apart from try and maintain a consistent tone.
There really is a world of difference from those that do voice overs for a living compared to those who don't, it's certainly not as easy as some seem to think.
- Joe -
Rockrooms Studio
Rockrooms
Posts: 141 Joined: Tue Dec 06, 2005 12:00 am Location: Oxford
Re: Voiceover
Post by archdake mkII »
Daniel Drummond wrote:Print the lyrics really really big so she can see them from a distance. Different needs, different resources...
Yep...
archdake mkII
Posts: 139 Joined: Wed Sep 01, 2004 12:00 am
Re: Voiceover
Post by Celsius »
Put a big TFT in front of her and use large fonts.
or maybe-->>this method
Celsius
Posts: 14 Joined: Fri Jan 16, 2004 12:00 am
Re: Voiceover
Post by BoogieBear »
Celsius wrote:Put a big TFT in front of her and use large fonts.
+1 for this method, used it many times
If you can't borrow some form of 'autocue' try editing the script in 'Word' or similar to have each section between breath intakes on one page and use the page or some method of autoscoll too run the script
Cheers
Anton
BoogieBear
Posts: 85 Joined: Tue May 01, 2001 12:00 am Location: Anglesey UK
You see when I was a young kid Elvis was top of the charts - That's 'Presley' not Costello!
