hi i use a roland gr33 at the moment with the midi out to a emu b3 for the hammond samples which sounds good as i play in a church worship band. my son has just got the gp 10 and its sounds realy good ,he trying to get me to sell the gr33 for a gp10 ,i am tempted but i cant see how to interface to the emu b3 sound modual ,can this be done
thanks
stuart
boss gp10
Re: boss gp10
Hi Stuart, and welcome to the SOS forums.
I'll try to make this as painless as possible. Sorry, the GP10 is not capable of controlling your Emu B3.
Your GR33 has a built in synthesizer AND a guitar to MIDI converter. This allows you to play the internal synth and control an external module. The GP10 uses modelling technology instead and has no guitar to MIDI converter.
To use your GK pick-up with both pedals together you would need to invest in more hardware. Roland make the US-20 pedal which takes your hex pick-up and allows you to switch it between two pedals or both together.
http://www.sweetwater.com/store/detail/US20
A third party makes a box that is more flexible than the US-20. It's called a UX-20.
http://www.joness.com/gr300/UX-20.htm
Hope that helps
Andy
Hope that helps
Andy
Is it about a bicycle?
