Pass cables through walls
Post by rokyronnie »
Hey guys, what is the best way to pass cable through isolated walls? without destroying too much of the isolation effect.
I found this: http://www.asc-studio-acoustics.com/pro ... pass-thru/
but it looks kind of expensive to me. Because I'm not sure how many cables I'll need (they can very by the time) I need something similar.
Thanks!
rokyronnie
Posts: 69 Joined: Mon Jul 23, 2012 12:00 am
Re: Pass cables through walls
Holes in walls, screw-on heavy panels on each side, with foam or similar to seal the edges and around the cables. Some pass throughs also use bags of dry sand stuffed in the holes on each side to add mass and improve the isolation. And make sure the cables have some slack between the walls.
Last edited by Hugh Robjohns on Fri Feb 10, 2017 10:00 pm, edited 1 time in total.
Posts: 43704 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
My holes are behind skirting boards or dado rails which are mounted away from the plasterboard wall (the whole studio is lined with fabric panels). I've used 2" diameter pipe and stuffed any spare space with Rockwool or foam.
Posts: 16993 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
