Reamp box
Reamp box
Post by curlybob43 »
Hi all
Has anyone got any recommendations for a cheap reamp box. I'm boosting the signal on the line out from my interface into guitar pedals and other outboard gear.
J
curlybob43
Posts: 78 Joined: Thu Jan 19, 2017 9:50 am
Re: Reamp box
Post by Dave B »
Orchid Electronics Amp Interface seems a good bet. They have an excellent reputation and it's only £56. Bargain.
http://www.orchid-electronics.co.uk/Amp_Interface.htm
Dave B
Posts: 5935 Joined: Thu Apr 03, 2003 12:00 am Location: Maidenhead
Re: Reamp box
On a tight budget you could try something like
http://www.ebay.co.uk/itm/AAM40L-Mono-A ... 2503988357
although I'd prefer a little less attenuation.
Personally, I've never had a problem connecting line outputs direct to guitar effects provided you keep the levels down.
Posts: 16989 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Re: Reamp box
Post by ore_terra »
I've got the Palmer one and it works fine
ore_terra
Posts: 1090 Joined: Fri Dec 02, 2016 12:56 pm Location: Seville - Spain
casmoestudio.com
Re: Reamp box
Orchid re-amp interface reviewed here:
http://www.soundonsound.com/reviews/orc ... -interface
Re: Reamp box
Post by Ben Asaro »
Here in the US it's easier to get Radial products. I have the ProRMP which is a passive reamp box. It works just fine!
Ben Asaro
Posts: 3484 Joined: Thu Feb 26, 2009 12:00 am Location: NYC
Re: Reamp box
Post by siderealxxx »
+1 Orchid
siderealxxx
Posts: 662 Joined: Sat Jan 24, 2009 12:00 am Location: Somerset
Excess makes the heart grow fonder
Re: Reamp box
Post by SleepyHollos »
James Perrett wrote:On a tight budget you could try something like
I used to do that too but then I saw the Orchid and thought I'd just take a punt at it for £56 delivered. It makes a big difference I find and having the ability to lift the ground at the flock of a switch is very nice too. I haven't tried the more expensive units so I can't say how they fare against it, but I find absolutely no weakness with the Orchid so I'm sticking with it and recommend it highly.
SleepyHollos
Posts: 2 Joined: Sat Apr 26, 2003 12:00 am
Re: Reamp box
Post by Mixedup »
Radial, Orchid, DAV, Palmer... there are loads of these things now. I have the DAV one, which is nice enough, and if you're using it with a specific piece of gear regularly, the levels can be trimmed using presets inside the box, which is handy.
But these things are pretty easy to build, too, and cheap as chips.
Eg. the DIYRE L2A kit. I note this one is currently out of stock. Still, it's an open source design, with schematic, manual and PCB layout on the site...
Mixedup
Re: Reamp box
Hi guys
Thank so much for all the recommendations, after checking them all out I think I'll go for the palmer or orchid one. Great finds for good products on a budget!!
curlybob43
