The Situation.
- My artist wants to radically remix a full band track... the key point being she wishes to remove the band and critically; the drums.
- Re-recording tracks is NOT an option. Just "no, can not do that"
- the drums are bleeding through on BG vocal and keyboard tracks. Thankfully, the lead vocal is ok. (For the record... I didn't cut these tracks!
She is ok with the level of bleed... I am not. You need to listen closely on headphones to hear the drums coming through. I have taken drastic steps to minimize the situation... but being a recording engineer... it's all I hear... little pips of drums... waaaaay back there somewhere.....ARRGG!
- Tight edits of the tracks and aggressive fades of the snippets into reverb to minimize exposure.
- Using the RX5 de-noise shaped expander/gate to go after the gack.
- RX5 Declicker to loose some transients.
- Minimal compression to not raise the bleed into the mix.
I thought about pumping some out of phase drums into the offending tracks to try and cancel it out... but I would have to match the dynamics and my head spins thinking about it.
As I was typing this out I thought I will try some severe notch filters. Might get away with automating that in.
Again.... I am forced to deal with it and the situation is such that I have to suck it up and make the best of it.
Thanks in advance! Maybe it's just pints at the pub...
