auto power-off for monitors with on/off switches only
Post by stemwinder »
Hi there,
I am thinking of moving monitors around and considering putting my Mackie MR5s where my HR624's are - on (high) wall mounts. The mounts both have a balanced 1/4 jack close by, and also electrical spurs with female IEC sockets running from them. All very tidy.
The HR624s have an auto power-off, but the MR5s do not, and it doesn't seem a good idea to leave them always on, but I don't want to use the rocker switch (too difficult to access).
Is there any gizmo out there that I can employ to make this (auto power off) happen? I doubt it, but it's worth asking!
Thanks,
Darren
stemwinder
Posts: 46 Joined: Wed Sep 01, 2004 12:00 am Location: gloucestershire
Re: auto power-off for monitors with on/off switches only
Post by Mike Stranks »
I don't see anything wrong in putting an accessible switch into the mains feed to those monitors. Could be either hard-wired or wireless.
If my monitors haven't auto powered off when I finish for the day then I just switch off at the wall. Been doing it for over a year with no apparent deleterious results.
Posts: 10589 Joined: Fri Jan 03, 2003 12:00 am
Post by Music Wolf »
This is what I did when I had to reach over the desk to hit the rocker switches. I had my monitors, plus any rack gear where the power switches were sited on the rear panel (why do designers do this?), all fed from an individually switched plug board.
I should really revert to this system as the rocker switches on my Adam A5s are something of a week link having replaced one that failed.
Music Wolf
Posts: 2894 Joined: Fri Feb 17, 2006 12:00 am Location: Exiled to St Helens
Post by John Willett »
I plug mine through an adaptor with a remote on/off switch - easy for switching mains in inaccessable places.
Something like THIS:thumbup:
You can also get them with two or three sockets from the remote - gust google.
John Willett
Posts: 7297 Joined: Tue Mar 07, 2000 12:00 am Location: Oxfordshire UK
Post by Dynamic Mike »
You can get 'intelligent' plug extensions, which when you power down whatever is plugged into the master socket, automatically switches off power to the rest of the board. Also, you can get adapters like John has posted above with hard wired remote switches, if like me you have a habit of hiding remote control boxes from yourself.
Dynamic Mike
Posts: 5291 Joined: Sun Dec 31, 2006 12:00 am
Why do bad things mostly seem to happen to people who light up a room when they enter it?
