DIY mastering made easy
Post by gingertimmins »
Hi guys,
I'm reading the article in this months mag and I'm interested in giving it a bash. I'm not in a position to buy any software at the moment and I'm wondering if ReaFir included with reaper would do the trick. It can build noise profiles and be used as a surgical eq (according to the site).
Is this a suitable tool for the job?
Cheers
gingertimmins
Posts: 498 Joined: Wed Dec 05, 2007 12:00 am
Re: DIY mastering made easy
Post by Zukan »
Hi Ginger
I have never used ReaFir so couldn't tell you buddy. Maybe one of the boys here could help out?
What is your main DAW?
Zukan
Posts: 10135 Joined: Fri Sep 12, 2003 12:00 am
'Shaka. When the walls fell. Zukan...with his arms wide.'
1-2-1 Tuition
Thanks for the reply zukan!
So I had a dabble with it comparing the article as best as I could with reafir. I'm not sure if what I did was exactly what the article intended but I did end up with some very satisfactory results which improved the tonal balance of the track so happy days there!
My main daw is cubase elements 9 (having downgraded from cubase 5 as it wasn't running well since moving to windows 10 and nowadays I don't need anything more than a basic toolset) and I'm using a couple of reaplugs in cubase.
I found a free tilt eq which is something that Reafir lacked and I'm getting decent results so I think I have everything I need.
Great article by the way, makes me want to revisit the mixing to pink noise article which I believe you wrote?
Anyways, nice one!
gingertimmins
Post by Zukan »
Great, glad it helped.
Doesn't Cubase Elements 9 have Curve EQ?
Zukan
1-2-1 Tuition
Post by Mixedup »
Zukan wrote:Great, glad it helped.
Not 100% sure but I doubt it — Elements has only 40 FX plug-ins compared with Pro's 90, and Steinberg obv pay a licensing fee to Voxengo for Curve EQ, so would make sense to make that one of the 'added value' features for the full fat version.
Mixedup
Post by Zukan »
Apparently there is a lot of confusion about whether Curve EQ is supplied with any of the Elements versions. However, there is this:
https://www.steinberg.net/fileadmin/fil ... ase_9.pdfI
Zukan
1-2-1 Tuition
Something wrong with the link Zuke as I get a 404 error.
This should work. https://www.steinberg.net/fileadmin/fil ... base_9.pdf
Post by Rich Hanson »
According to the plugins manual for Cubase Pro 9, only Cubase Pro and Nuendo have CurveEQ
Rich Hanson
Posts: 3686 Joined: Sat Sep 06, 2003 12:00 am Location: Sort of near Rochester, Kent, UK
Post by Mixedup »
Zukan wrote:Apparently there is a lot of confusion about whether Curve EQ is supplied with any of the Elements versions. However, there is this:
Fixed the link for you :angel:
That PDF confirms that Curve EQ is, as I suspected, bundled with the full-fat version of Cubase only. (It's $79.95 direct from Voxengo if you wish to add it to other versions.)
Mixedup
