Mounting the C414
Mounting the C414
Hi there, is it a 25mm shock mount I will need for a C414? I've bought an AKG SA60 for one of the pair, but I want a cradle for the vocal mic and I'm just checking I've got the size right.
Also considering the Rode stereo bar for coincident XY and M/S configurations. Does anyone have any opinion on these?
- Richard Graham
Posts: 1800 Joined: Mon Apr 10, 2006 12:00 am
Re: Mounting the C414
I use a Rode bar, in combination with a couple of Rycote Invision mounts. This works well for me and I find it easy to set the mics up the way I want them. The one problem I have found is the joint between the bar and the socket that connects to the mic stand. This can get loose and the bar will droop. To tighten the joint properly requires 2 screwdrivers. Rode should have devised something better for this joint. Despite this I'd probably buy it again.
- ConcertinaChap
Jedi Poster -
Posts: 15242 Joined: Wed Jul 20, 2005 12:00 am
Making music: Eagle Alley
Thanks CC!
Does anyone have any advice on the right size of shockmount/cradle thingy? I've Googled and looked at PDFs of the C414 spec, but can't see the dimensions of the "stem" listed anywhere.
- Richard Graham
You need to mont it either in the pukka AKG cats cradle mount designed specifically for the C414, or a Rycote Studio InVision mount. The AKG mount is the H85 and it costs around £45. It is very good value for money and works very well. I wouldn't use anything else, actually.
You can't (or shouldn't) use a standard SDC style shock mount on the stem as the axis of maximum shock isolation is in completely the wrong plane.
Last edited by Hugh Robjohns on Sun Nov 05, 2017 11:12 pm, edited 1 time in total.
Posts: 43698 Joined: Fri Jul 25, 2003 12:00 am
Richard, can't you just get a girlfriend?
I mean, mounting a mic became illegal back in 1847.....
Zukan wrote:Richard, can't you just get a girlfriend?
Ha ha, I suppose I could but I don't think my wife would be too happy!
Zukan wrote:I mean, mounting a mic became illegal back in 1847.....
First I heard of it! I'll stick to looking in glossy mags then (like SoS!)
Last edited by Richard Graham on Mon Nov 06, 2017 9:34 am, edited 1 time in total.
- Richard Graham
Hugh Robjohns wrote:You need to mont it either in the pukka AKG cats cradle mount designed specifically for the C414, or a Rycote Studio InVision mount. The AKG mount is the H85 and it costs around £45. It is very good value for money and works very well. I wouldn't use anything else, actually.H
Thanks Hugh, so is the SA60 no good then? I've ordered one because I thought they were made by by AKG specifically for the C414?
The H85 is a bit more costly these days by the looks of things. Still worth paying for, I'm sure!
- Richard Graham
Richard Graham wrote:Thanks Hugh, so is the SA60 no good then? I've ordered one because I thought they were made by by AKG specifically for the C414?
The SA60 will fit the C414's base stalk and it's a perfectly good 'hard' stand adaptor... but it's not a shock-mount.
Richard Graham wrote:The H85 is a bit more costly these days by the looks of things. Still worth paying for, I'm sure!
Both GAK and Andertons are currently advertising it at £45:
https://www.gak.co.uk/en/akg-h-85/603?gclid=EAIaIQobChMIjJLWhuKp1wIVgkIYCh10mQMtEAQYAiABEgJ3E_D_BwE
https://www.andertons.co.uk/akg-h85-universal-shockmount-(works-with-c414-se2000-sex1-sex1r-and-more)-h85?LGWCODE=H85;56375;6335&gclid=EAIaIQobChMIjJLWhuKp1wIVgkIYCh10mQMtEAQYASABEgLo7_D_BwE
...but yes, It is worth it even at £55 -- especially in comparison to the appropriate Rycote Studio InVision model which is more like £75, or Neumann's utterly ludicrous EA1 shock-mount for various TLM mics which costs over £200.
The beauty of the H85 is that not only is it an effective and affordable shock-mount, but it's really quick and easy to install and remove the mic too.
Last edited by Hugh Robjohns on Mon Nov 06, 2017 10:49 am, edited 1 time in total.
Thanks Hugh. Had the same issue here with Tom's 103....
To avoid any confusion, the AKG H85 only works on a small range of mics which have an appropriate diameter and length of stalk -- but it is the perfect solution for the C414, C3000, etc.
For the Neumann TLMs, I'd go with the Rycote Studio InVisions because they are technically superior to the EA1 and less than half the price.
Hugh Robjohns wrote:Richard Graham wrote:The H85 is a bit more costly these days by the looks of things. Still worth paying for, I'm sure!
Get in! Thanks very much indeed Hugh!
- Richard Graham
Richard Graham wrote:Hi there, is it a 25mm shock mount I will need for a C414? I've bought an AKG SA60 for one of the pair, but I want a cradle for the vocal mic and I'm just checking I've got the size right.
The Rycote USM-L is the one to go for - none better and not expensive.
- John Willett
Longtime Poster -
Posts: 7297 Joined: Tue Mar 07, 2000 12:00 am
John Willett wrote:Richard Graham wrote:Hi there, is it a 25mm shock mount I will need for a C414? I've bought an AKG SA60 for one of the pair, but I want a cradle for the vocal mic and I'm just checking I've got the size right.
Thanks John, it seems we have a (slight) disagreement. "Infinite are the arguments of mages". (Ursula K. LeGuin).
In principle, I like the idea of the Rycote, because I could use it with any microphone, not just the 414, but I'm swaying towards the HA85, purely because of what Hugh says about it being easy to dismount the mic.
I plan to take the pair of them home with me from my practice rooms up to 3 times a week. It looks like if would be more of a faff to dismount and re-mount with the Rycote.
- Richard Graham
Well in fact you’re talking one second versus three for the Rycote, so it depends on how precious your time is. I happen to have both and generally use the H85 on the C414, but it’s not a big time waster!
- Bob Bickerton
Longtime Poster -
Posts: 5641 Joined: Fri Dec 20, 2002 12:00 am
Richard Graham wrote:In principle, I like the idea of the Rycote, because I could use it with any microphone, not just the 414, but I'm swaying towards the HA85, purely because of what Hugh says about it being easy to dismount the mic.
John is right in so far as the Rycote In Vision shock-mounts are superbly designed and engineered and proven to work very effectively (assuming the right lyre compliance is used which depends on the weight of the microphone -- hence the many different models and compatibility charts). Also, there's nothing to wear out -- no elastics that can break, or go saggy, or come unhooked!
The Rycote mount is also massively cheaper than the Neumann cat's cradle shock-mounts, and also cheaper than the bespoke mounts of many other manufacturers. And you can attach a dedicated pop-screen to the mount which is very good and highly practical. These are all good things and make the Rycote Studio InVision mounts very attractive. I have a dozen of them in various weight ratings and recommend them to people all the time.
However, the Rycote is a little fiddly to mount microphones because of its universal multi-clamp design and -- and this is the key point here -- they are nearly double the price of AKG's own cat's cradle shock-mount for specifically intended for the C414 (and similar mics).
Now, if the H85 was a crap design I'd recommend the Rycote without hesitation. But it's not a crap design; it's actually a very good design, and it's almost half the price of the Rycote. I never put my own C414s in Rycotes as there is no point. The H85 is easier to use and just as effective as a shock-mount... seems a no-brainer to me.
Yes it would. With the H85 it's a quarter-twist of the locking ring, lift out the mic, unplug the XLR and you're away. And installation is the exact reverse. With the Rycote you have to support the mic with one hand, loosen at least two if not three of the thumbscrews, then remove the mic and unplug. It doesn't take much longer but it is considerably more fiddly...
On the other hand, if you leave the mic in the shock-mount (as I do), unplug the XLR, and then simply unscrew the mic stand from the shock-mount it takes the same time for both!
And one final thing: if you're using the mic for vocals, a pop-screen is essential (as much to keep moisture (and worse) out of the mic as to stop pops). The Rycote has the advantage here as the dedicated pop-screen fixes straight onto the mount, always stays in the right place, and the foam is highly effective, inaudible, and easy to clean.
If you're using the H85 you'd need a separate pop-screen, and those multi-layer fabric ones on goose-necks can be audible, are a pain to clean and are guaranteed to droop at the most inopportune moment!
At the end of the day you pays yer money and takes yer choice. There are pros and cons for both...
Last edited by Hugh Robjohns on Tue Nov 07, 2017 10:53 am, edited 1 time in total.
Richard Graham wrote: It looks like if would be more of a faff to dismount and re-mount with the Rycote.
It's pi** easy to dismount and re-mount a mic. in the Rycote USM.
Once you have done it once you only need to give a small turn to two of the screws and it comes out easily - to remount, just put it back and give a small turn to the same two screws.
And - the Rycote Lyre is technically the best shockmount there is. Much better than elastic suspensions.
- John Willett
Longtime Poster -
Hugh Robjohns wrote: The Rycote mount is also massively cheaper than the Neumann cat's cradle shock-mounts, and also cheaper than the bespoke mounts of many other manufacturers. And you can attach a dedicated pop-screen to the mount which is very good and highly practical. These are all good things and make the Rycote Studio InVision mounts very attractive. I have a dozen of them in various wight ratings and recommend them all the time.
However, it is a little fiddly to mount microphones in them because of their universal design
They are only a little fiddly the first time - if you are putting in and taking out the same mic. it's easy as you only have to slightly loosen a couple of the screws so the settings stay the same.
- John Willett
Longtime Poster -
It may be worth noting that the Rycote Invision Universal Popfilter https://www.thomann.de/gb/rycote_invision_universal_popfilter.htm fits the AKG H85 just fine........
And if you keep the mics permanently in their shock mounts, I'd highly recommend the Triad-Orbit retrofit system https://unityaudio.co.uk/product/683/ior/ for quick and safe stand mounting.
- Bob Bickerton
Longtime Poster -
Bob Bickerton wrote:It may be worth noting that the Rycote Invision Universal Popfilter https://www.thomann.de/gb/rycote_invision_universal_popfilter.htm fits the AKG H85 just fine........
I hope their products are better than their spelling........
......which I'm sure they are!
They are........ that's American slang for very quick........
- Bob Bickerton
Longtime Poster -
Wow. So much great information and experience on this thread. Thanks fellas. It's most definitely down to the HA85 and the Rycote now.
What Hugh said about the pop-filter, combined with the fact that it can't wear out, and may not be that hard to dismount (i.e. loosen a couple of screws, as John says) is swaying me a bit towards the Rycote, but Bob - you seem to be saying that the pop-filter will work just as well with the HA85 as with the Rycote?
What's the issue with wear on the HA85? Does the elastic gradually deteriorate?
- Richard Graham
Richard Graham wrote:What's the issue with wear on the HA85? Does the elastic gradually deteriorate?
I've been using mine for well over a decade without any problems, but potentially the elastic cords may deteriorate over time. Replacements are available. However, the design is better than many, and wear isn't a big issue here, unlike some other simpler cats' cradles.
Ok. Possibly my last question on the subject. Is there any reason, other than cosmetic, that I shouldn't get one of each? i.e. Rycote with the pop-filter (which I need), and an HA85.
(Bearing in mind I want to use them in X/Y or M/S mode sometimes, with a mic bar.)
- Richard Graham
