Recommend Analogue Saturation/Preamp plugin (non iLok)?
Post by dickiefunk »
Hi,
I'm looking to buy a VST plugin that can add some analogue saturation/preamp emulation to my mixes.
What would you recommend that doesn't use an iLok dongle?
dickiefunk
Posts: 2099 Joined: Fri Jun 17, 2005 12:00 am Location: Cornwall, UK
Re: Recommend Analogue Saturation/Premp plugin (non iLok)?
Post by Aled Hughes »
I use IK Multimedia's EQ73 and Saturator X a lot. I like 'em.
Aled
Aled Hughes
Posts: 2136 Joined: Tue Oct 24, 2006 12:00 am Location: Pwllheli, Cymru
Post by muzines »
dickiefunk wrote:I'm looking to buy a VST plugin that can add some analogue saturation/preamp emulation to my mixes.
Decapitator is good and currently on sale - $199 -> $49
http://www.soundtoys.com/product/decapitator/
dickiefunk wrote:What would you recommend that doesn't use an iLok dongle?
You don't need to discard iLok software just because you don't want a dongle - these days iLok software can usually be either done with a dongle, or a hard-disk authorisation (which doesn't require a dongle) - your choice.
muzines
Decapitator is good, but for free I'd suggest you give GClip a try.
Posts: 21434 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by Sam Inglis »
Decapitator is great, and I also use SoundToys' Radiator a lot for this.
FabFilter's Saturn is really cool, too, but it takes a bit more setting up.
Sam Inglis
Posts: 3228 Joined: Fri Dec 15, 2000 12:00 am
Post by LimitedHeadroom »
I second the Soundtoys plugins already mentioned, the Klanghelm plugin, I think it’s called something like SDR22 is also excellent and extremely affordable. I often like it more than decapitator.
LimitedHeadroom
Posts: 64 Joined: Sun Sep 07, 2003 12:00 am
Post by ore_terra »
Waves NLS
ore_terra
Posts: 1090 Joined: Fri Dec 02, 2016 12:56 pm Location: Seville - Spain
casmoestudio.com
Many thanks. I can pick up Soundtoys Decapitator for $44 from JRRSHOP which seems like a great price. I’ll definitely try the demos of the recommended suggestions.
dickiefunk
LimitedHeadroom wrote:I second the Soundtoys plugins already mentioned, the Klanghelm plugin, I think it’s called something like SDR22 is also excellent and extremely affordable. I often like it more than decapitator.
I have both, and like them both in different scenarios, but Klanghelm's SDRR is an absolute steal at 23 Euros!
Have a look and listen here dickiefunk:
https://klanghelm.com/contents/products/SDRR/SDRR.php
Posts: 22574 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Thanks for the replies. I am looking to use something on the master buss to add a little analogue warmth.
dickiefunk
Re: Recommend Analogue Saturation/Preamp plugin (non iLok)?
Just bought Klanghelm's SDRR, MJUC and VUMT deluxe for £7 each from the 'sell &buy' at KVR!!
dickiefunk
dickiefunk wrote:Thanks for the replies. I am looking to use something on the master buss to add a little analogue warmth.
A bit of lower mic EQ boost might be all you need for 'warmth'. Don't be convinced by all this talk of analogue 'warmth' as being something that can be defined and added to a mix.
Many people bandy the 'W' word around in the same way that spiritualist charlatans use the word 'energy'.
dickiefunk wrote:Just bought Klanghelm's SDRR, MJUC and VUMT deluxe for £7 each from the 'sell &buy' at KVR!!
Hope you enjoy them dickiefunk!
Do report back when you'e had a play :geek:
Post by Zukan »
I use them all the time. Highly underrated.
I also have Decapitator which I think is excellent but for me Saturn reigns supreme along with SSL's X-Saturator (that damn Harmonics dial has changed my life).
I am really getting into IK Multimedia's Clipper.
Zukan
Posts: 10135 Joined: Fri Sep 12, 2003 12:00 am
'Shaka. When the walls fell. Zukan...with his arms wide.'
1-2-1 Tuition
