best sequencer for loops?
Post by kcseb »
Hi all
I'm a long-time Cubase user. I record traditionally (i.e. full length multi-tracking) but also like working with loops, building tracks based on layering loops on top of each other and pitch-shifting and tweaking as needed.
I currently use Stylus RMX for this, an old VSTi plugin (mainly aimed at drum users) which can import REX, WAV, loops, etc. However it's a clunky solution and a bit like using a 'sequencer within a sequencer', so not a great workflow.
What other software could I look at that allows you to create tracks based on layering up loops quickly and intuitively?
Thanks!
kcseb
Posts: 84 Joined: Sat Mar 24, 2001 12:00 am Location: London
Re: best sequencer for loops?
Post by fatbenelton »
Not sure what platform you are on but PC only Magix Acid should do the trick. Just updated to Pro 8 after languishing under Sony for years.
https://www.magix.com/gb/music/acid-pro/
It's a full fat sequencer though so may not suit your workflow alongside Cubase.
fatbenelton
Posts: 708 Joined: Thu Aug 22, 2002 12:00 am Location: Liverpool, UK
Jonny
I don't have any interest in loops, so it's not something I've made a study of, but I know that Cubase has tools in there to help with tempo-matching, slicing, stretching and stuff like that. It would be worth seeing what can be achieved by Cubase itself before pulling in a plug-in.
Again, I've never used it, but Ableton is more geared towards loops than Cubase, and it is from the same stable.
Post by Aled Hughes »
I use Bitwig Studio a lot. I like it.
Aled Hughes
Posts: 2136 Joined: Tue Oct 24, 2006 12:00 am Location: Pwllheli, Cymru
Post by muzines »
Wonks wrote:Again, I've never used it, but Ableton is more geared towards loops than Cubase, and it is from the same stable.
+1
"Live" has a great set of tools for this kind of material, and is a great complement to a more conventional DAW, imo.
muzines
Post by fxsoundscapes »
hmmm.. I use Cubase but usually i see all the loop people using FL Studio. They say its simpler to use but after working with Cubase for 10 years, i cant figure it out. Use what you know the best! :ugeek:
fxsoundscapes
Posts: 14 Joined: Thu Aug 16, 2018 7:29 pm
