Guitar multi fx with decent looping time
5 minutes or more will do, more would be nice (and loads of memory slots) but the usual 40 sec or so is pretty useless.....
Re: Guitar multi fx with decent looping time
Is this for some prog rock epic where the intro takes 5 minutes before you can start to add things on top?
No, much more prosaic :) I just want a single fx unit that will do everything, rock trio, acoustic trio and solo/duo (both instrumental and vocal). The looper is mostly for the full AABA (or WHY) rhythm guitar to solo over (so 90 secs minimum before overdubs). The TC Helicon VoiceLive 3 Extreme does it but is, primarily, a vocal fx unit (though the guitar fx are very good). So does the Helix but at a price..... TBH I don't need loads of effects, my electric pedalboard has a Cry Baby wah, clean boost, TC Dual Vintage Distortion (more or less two Tube Screamers in a box) a delay, a reverb, a tuner and a looper, the acoustic one needs, boost, delay, tuner and looper. A decent eq for acoustic would be nice too, though I suspect all the more sophisticated boards will have one.
Mind you I do dream of being in a Prog Rock band (but probably don't have the patience and ability) so you never know......
Post by Hewesy »
The Helix does do it all, a number of pro's use them for everything (including acoustic) but as you note, it does have a pro price tag...
Does it have to be a single unit? What about a small board with a wah, MFX like say the Line 6 M series or the cut down Helix and then a looper?
Given the hands on nature of the looper I'd suggest having this as a dedicated box might make your life easier. And you can then easily swap loops around for gigs/rigs etc.
What puts you off using the electric board for acoustic, noting you use pretty much the same kit for both?
Hewesy
Hewesy
Posts: 866 Joined: Tue Oct 19, 2004 12:00 am
Sam Spoons wrote: The looper is mostly for the full ABBA rhythm guitar to solo over
OK, Björn.
Helix will give you 60 seconds stereo, 120 seconds mono. I can't think of a hardware looper that would take you further (TBH I can't imagine wanting more than 120 seconds of loop!)
With the Helix you could leave all your other stuff back home. It isn't cheap, but it really is very good indeed. Once you discover the multiple I/O capabilities (four simultaneous stereo inputs, each with separate effects chains, for example), mic input, USB/MIDI, multi-channel audio interface and other goodies, you really do begin to realise that it's a whole lot more than a stomp box replacement.
There are cheaper Helix versions (and I believe they are all patch-compatible), but you have to accept compromises as the price drops.
Hewesy wrote:The Helix does do it all, a number of pro's use them for everything (including acoustic) but as you note, it does have a pro price tag...
I do have a second board for acoustic which has just boost, tuner, delay and Ditto X2 Looper
See above, but I have just sold the TC Ditto mini (off the electric board) and Ditto X2 and bought two DittoJam X2s as they claim to be able to stay in sync with a live drummer or rhythm player. Jury's out as I've only just got them but will report back.
Hewesy
Size plain and simple, it's quite big and heavy. Losing the wah, distortion and reverb (the AER acoustic amp has one built in, the 18 watt combo doesn't) makes a lot of difference and the acoustic board is less than half the size/weight. It also runs off a PedalTrain Volto so no mains needed which is great for open mic sessions (mains power requirement may be a reasons not to go for an all in one solution).
Post by BigRedX »
The Helix might seem expensive, but for what it does and what it costs in real terms it's a complete bargain.
My first multi-effects unit was a Roland GP8 which I bought second hand in the late 80s, and did only a fraction of what the Helix is capable of, but IIRC only a couple of years earlier the new price for this and foot controller to go with it was close to £1k when that was worth a lot more in real terms compared with £1k today.
BigRedX
The Elf wrote:Helix will give you 60 seconds stereo, 120 seconds mono. I can't think of a hardware looper that would take you further (TBH I can't imagine wanting more than 120 seconds of loop!)
I might consider the Helix, one of my guitar heroes (Remi Harris) uses one and have looked at the TC VoiceLive 3 Extreme as I mentioned above.
The VL3E has, I think, 5 mins looping as do the Ditto series but no loop memories, I also have a Boss RC3 as a 'gig bag looper' and a Boss RC30 both of which have 3 hours stereo loop memory and 99 memory slots. So I'm well endowed with loop pedals :D For me an all in one box would, ideally, have loop memories and much more than 2 mins of looping to store some loops as playing the full rhythm part before every song becomes a bit tedious for the audience (as you may have realised I use a looper mostly as a surrogate rhythm player). :D
BigRedX wrote:The Helix might seem expensive, but for what it does and what it costs in real terms it's a complete bargain.
I have had a Boss GT3 for many years, which replaced my GX700 rack and FC200 (I still have the FC200)
Elf? can the Helix do basic vocal harmonies? The thing that stops me buying a VoiceLive 3E (and I've had several VL products, Harmony G, VL1. VL2 and currently VL Play GTX) is that it compromises the guitar fx (obviously) in favour of the vocal fx and what I want is the other way around, good guitar fx, a decent looper (and yes 2 mins would probably be enough for most things but see my earlier post) and basic vocal harmonies in one box.
I will download and read the Helix manual later I promise ;)
Writing this reminds me I need to perform another cull of fx/stomp boxes
Sam Spoons wrote:Elf? can the Helix do basic vocal harmonies?
Hmmm... It has a harmoniser in there, but I doubt that it would be suitable for vocals.
This guy on YouTube details adding a TC Helicon in a loop from the Helix: https://youtu.be/MZC5QZocKLQ
If you're at the SOSMeet tomorrow I can bring mine along?
One day maybe but it's a bit of a trek and not tomorrow. Thanks for the offer though. TBH the guitar fx on the Play GTX are pretty decent and probably do enough but the 30sec loop time is not enough to be useful for my needs so I'm back up to two boxes :headbang: . Probably a TC Harmony Singer and a guitar multi fx would be the way to go but I already have all of those facilities and it's still 2 or more boxes. I've just rebuilt the acoustic board with a Ditto Jam, mini delay and the Tone Dexter (which does boost and has a tuner) so I'll try that for a while while reading up on various guitar fx units.
Maybe I should document my current fx collection, it seems to be pretty extensive......
Post by Hewesy »
Fair enough Sam, just curious but yes that makes perfect sense.
What about splitting the boards into 2 small Pedaltrain units? Would also make 2 lighter boards to move rather than one unwieldy beast... wouldn't take much to have a loom made to connect both up as needed.
Great taste with Remi Harris, what a talent...
Hewesy
Hewesy
It's not too unweildy only a PT Mini with 7 stompers on it (the gap is where the TC Ditto was before I gave it to my mate the bass player, it will be replaced with a DittoJam X2 shortly, the other couple of boxes are an Airturn and associated footswitch). I'm happy using it for it's intended purpose, it's the acoustic board I'm trying to resolve really, currently it has a TC DittoJam X2, a mini delay and the Tone Dexter. I think it may be that I'm suffering from pre-Christmas GAS rather than any need to change.....
Remi Harris is one of my two favourite Gypsy Jazz guitarists (neither of them Gypsies as it happens) Joscho Stephan is the other. Both are not to shabby playing other styles either :D
Joscho is here (this filmed ten years ago now) :-
https://www.youtube.com/watch?v=99R7VW9QqyY
Post by CS70 »
Sam Spoons wrote:5 minutes or more will do, more would be nice (and loads of memory slots) but the usual 40 sec or so is pretty useless.....
The trio band creator allows 230 secs if I recall.
Yeah considered one but doesn't really do the other stuff I need. I find it hard to understand why otherwise brilliant devices like the Helix include a looper but then only give 60 secs of stereo loop memory (and no loop storage) when a £60 looper like the TC Ditto can have 5 mins of stereo loop memory and a £100 one (the RC-3) has 180 mins of stereo loop memory and 99 memory slots. Compared to the cost of a Helix the cost of extra memory can't be an issue. I still wonder if a VoiceLive 3X at half the price of a Helix would do what I need but it seems daft to pay for loads of vocal fx, most of which I won't use........
Maybe at a future update the Helix will include some vocal fx and more loop memory (though that's probably a hardware limitation).
Sam Spoons wrote:Mind you I do dream of being in a Prog Rock band (but probably don't have the patience and ability) so you never know......
The Dark Side Of The Spoons.
:clap::clap: On the other 'dark side' I was asked last night, at an open mic, if I fancied joining a Blues band :D t'is nice to be asked but I like the guys I gig with now and wouldn't fancy having to re-navigate the twists and turns of band politics again.
Post by Guest »
The Helix is good but the pitch based stuff is bloody awful.
For vocal harmonies you would be better getting the audience to help.
Guest
:lol: tried that, it's hard enough getting the band to help some gigs.....
What is this 'audience' you speak of?
I wish I knew......
Anyway a couple of days reading manuals and reviews plus this thread seem to have suppressed the GAS, temporarily at least, so thanks everybody, I'll see what I can do with what I have (to which end I have bought a couple of metres of real 'Velcro" and have some posh melamine faced plywood in the garage) :thumbup:
A quick update, The acoustic pedalboard now has The Tone Dexter, into a standard sized TC Flashback Delay (more sophisticated than the Mooer) and the TC DittoJam X2.
The electric board has the other DittoJam X2 added.
WRT to the DittoJam X2, it does track the drums tempo very well as long as it has a strong signal, feeding a drum machine into it works a treat, stomping the floor alongside less so. And it does very weird things if you run in sync mode without a decent sync input (random, huge tempo changes). It has three modes, 'BeatSense' mode (where tempo tracks the sync input), practice (where tempo is adjustable but doesn't need continuous sync input, great for slowing stuff down for practice) and 'Classic' (normal loop mode), switching between modes is, thankfully, easy with the foot switches. Definitely think it'll be a keeper. Best deal by a long way (shipped to the UK) is from Thomann where it's £114 instead of £180-200.
