Headphone earpads suddenly degraded and sticky
Post by Jumpeyspyder »
Hi All,
Pulled out my DT100s earlier today and they were suddenly very nasty!
(Had them 15 years so not too bad ) but were fine last time I used them!
Same happened to Sennheiser HD212 5 year ago
HD 25s also 15 years old are just starting to feel clammy
I can get replacement pads - but is there anything I can do to prolong earpad life ?
Jumpeyspyder
Posts: 1363 Joined: Fri Jan 20, 2006 12:00 am Location: Yorkshire
Re: Headphone earpads suddenly degraded and sticky
:lol: 15 years out of a set of $10 ear pads? I think you're doing pretty well TBH.........
I imagine it is sweat (which is acidic) that eventually destroys the plastic ear pads (I had a set of Sennheisers with foam pads do the same many years ago) so wiping them with a damp cloth after use should help. Get back to us in 2033 and let us know ow you got on ;)
Posts: 22896 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by Guest »
A warning: a few years ago I used an old pair of high quality monitoring headphones that I had got used to and didn't want to change. The vinyl covering had come off and headphones often make my head sweat. I then discovered I had a flaky scalp, skin started peeling off, and my hair started thinning because there was little unaffected scalp. This was almost certainly the result of using these headphones. It took ages to find a cure although when I did the problem went away in two and a half weeks.
When I went to the same shop to replace them the updated version were even better and cheaper.
Guest
They go like that. One pair of DT100s lasted only around 18 months before they became like sticky liquorice and artists were wandering around with black rings around their ears!
Posts: 21430 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Just happened to my car steering wheel as well, which is just old enough to drink in the US.
Posts: 29708 Joined: Sun Jul 05, 2015 12:00 am Location: York
