Multi-track recording on the cheap
Post by dallascaley »
Here is what I would like:
A) A mixer with 8 inputs (XLR or 1/4 Phono)
B) A mixer that can either record the 8 inputs directly on to a usb thumbdrive (while preserving all 8 tracks as individually editable) or one that can send a signal via USB (or firewire) to my Mac where i can record the 8 tracks.
I have been told that this will do the job: Behringer X Air XR16. however in all of the descriptions of the product it only mentions stereo recording.
I don't know If I am asking the right question because the answers i get are not specific so this is exactly what I would like to do:
A) Set up mics on all the instruments in the band (3 on the drums)
B) Record us playing live, all at the same time
C) have some sort of editing software where I can go back in after the fact and adjust the levels of each of the 8 tracks separately.
What is the best/cheapest way to achieve this?
dallascaley
Posts: 3 Joined: Wed Feb 20, 2019 12:03 am
Re: Multi-track recording on the cheap
Post by Bob Bickerton »
There’s lots of options and a consideration for you will be what extra functionality would you want from the mixer.
QSC TouchMix and Zoom Livetrack L-12 spring to mind and I believe a number of the Allan and Heath digital desks allow direct recording to thumb drive.
Bob Bickerton
Posts: 5639 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
Post by Dan LB »
Welcome to the forum.
Yes you are correct that the XR16 will not do what you want.
Seeing as you have a Mac already, might I suggest the Behringer UMC1820?
8 microphone inputs, connects by USB to your computer for recording the individual tracks in your DAW of choice. Around €185.
Other features include MIDI i/o and ADAT which allows you to add a further 8 mic inputs at a later stage if you want.
Dan
Dan LB
Posts: 1691 Joined: Sat Jan 28, 2006 12:00 am Location: Wicklow, Ireland
Post by The Korff »
The Behringer UFX1604 would seem to be just the ticket — and per this thread, the prices on them seem to have dropped significantly!
https://www.soundonsound.com/forum/view ... 04#p583074
BUT... I've just Googled around, and availability seems to be a bit of an issue. If you can find one around the £300 mark though (as forumite Mike Stranks did recently), you'll be laughing.
Good luck!
Chris
The Korff
Posts: 2279 Joined: Fri Jan 08, 2010 11:28 am Location: The Wrong Precinct
Post by Music Wolf »
Another vote for the Zoom Livetrak L-12 (or L-20 if your budget can stretch).
I've had mine since Christmas and I've used it to;
Capture rehearsals (2 or 3 mics on kit)
Record drums
Mix us live on stage inc individual monitor mixes for the band
Record our gig (as I would a rehearsal)
It has it's shortcomings (as you would expect at the price), most notably the lack of effects on the aux mixes, but it is excellent when it comes to capturing stuff 'on-the-fly'. You can hit record then play and it starts recording all armed tracks to a folder. Hit stop and it takes a couple of seconds to store the data then hit rec + play and you are off again recording to a new folder. It really has been thought through from a musicians point of view.
Music Wolf
Posts: 2894 Joined: Fri Feb 17, 2006 12:00 am Location: Exiled to St Helens
The Berry XR18 will do what you want but, obviously, costs more than the XR16. The XR16 can only record a stereo mix.
Behringer mixers are incredibly cheap in the UK at present, XR16 is £260, XR18 - £330 and even the X32 Rack is only £608 which is nearly £400 cheaper than when I bought mine :headbang: (all prices from Thomann)
Post by CS70 »
dallascaley wrote:Here is what I would like:
If you find an Alesis Multimix 2.0 8 or 16, it's very economical and does a lovely job - will transfer your individual tracks to a DAW with no problem (no USB drive tough)
Do you need this to use as a standalone mixer as well as for recording?
Post by Mike Stranks »
Sam (Spoons): I'm not sure that the XR18 can record direct to external hard drive/USB stick.
OP: if you don't want sophisticated 'mixing' facilities then the Zoom R16/R24 might suit.
But I'd agree that overall probably the Zoom Livetrak will be your best option.
(I think you've missed the boat on the UFX1604. They were cheap because it was end of line and now most have been sold at the bargain price for which I got mine.)
Mike Stranks
Post by Sam Inglis »
@Music Wolf, have you updated your L-12 to the latest firmware? The L-20 does allow you to have effects in the aux mixes, and I was told this is down to new firmware which is also available for the L-12.
Sam Inglis
Posts: 3228 Joined: Fri Dec 15, 2000 12:00 am
Mike Stranks wrote:Sam (Spoons): I'm not sure that the XR18 can record direct to external hard drive/USB stick.
You are right Mike, The XR18 can't record multitrack to a USB drive only stereo but the OP asked for the ability to record 8 tracks either to a USB drive or to his Mac over USB. :thumbup:
Sam Inglis wrote:@Music Wolf, have you updated your L-12 to the latest firmware? The L-20 does allow you to have effects in the aux mixes, and I was told this is down to new firmware which is also available for the L-12.
No I haven't. I hadn't heard about this, I'll check it out immediately.
Thanks for the tip :thumbup:
Music Wolf
Well that's worked. Happy days :D
Music Wolf
Wooo!
Sam Inglis
Post by Humble Bee »
Oh thats good news indeed. The only reason I hesitated a bit. :thumbup:
Humble Bee
Posts: 395 Joined: Mon Jan 08, 2007 12:00 am Location: Cloughton Newlands
Post by OneWorld »
Be aware that many of the mixers that allow multi-track recording only allow all the tracks to be recorded at the same time, whether the tracks are empty or not. In other words, if the mixer allows 16 tracks to be recorded, they have to be done concurrently, there is usually the option to record a stereo track too.
The exception to this is the TASCAM Model 24 (and the Zoom L12, L20 I would think) which does indeed function as a multi-track recorder would.
I almost bought a A&H QU16 as it records 16+2 tracks and thought great, a Portastudio that's a mixer as well - well, no, not quite
OneWorld
Post by Dan LB »
I’m not entirely sure that the OP needs a mixer. I thought he just wanted the cheapest way to record multiple tracks and *thinks* that a mixer is required - apologies if this is not the case
Dan
Dan LB
Good shout Dan, if all the OP needs is an 8-pre interface then something like a Tascam US 16x08 would do the job at around £200
Ah yes! I'd thought he'd wanted a both/and ability... looking at his spec again it's either/or... :thumbup:
Mike Stranks
Holy crud!, I am amazed and impressed by the response to my very first post in this forum that I just discovered yesterday. If you people all got into software development (my field) we would probably not have so much crappy software, anyway.
So, there is a lot to digest here, sorry for not replying individually.
I've done a cursory review of all the products suggested to me and I am leaning towards the Behringer UMC1820. While it does not record directly to usb card it will do it directly to my Mac and that's probably better anyway.
As for the others, I'm not seeing any of them that explicitly state that you can record 8 tracks individually. There's one that says it will do 4 but that's not enough.
Also someone else mentioned that I probably don't really know what I'm asking for in that I am asking for a mixer. I think this person is correct. I don't really want a mixer i simply want an 8 track recorder. I'll let the software do the mixing part.
Again, thanks all for your support and welcoming a newcomer to this forum. I'll keep you posted on what I end up doing.
dallascaley
https://www.zoom-na.com/products/production-recording/multi-track-recorders/zoom-r16-recorder-interface-controller
Definitely records 8 discrete tracks - I owned one several years ago. Records to SD card or via USB to computer, but not both at the same time!
Mike Stranks
Thanks Mike, I do see that it says 8 tracks simultaneously so this is in the category of devices i will consider. So, the main advantage I can see with this device over the Behringer UMC1820/Mac Laptop setup is that if I wanted to go record a live show I wouldn't have to worry about lugging around my Macbook and worrying about it getting stolen or beer spilled on it... which is definitely a good thing.
It does cost about $130 more however (at the moment on sweetwater). I also like that it can record to usb sticks so that's a huge advantage because i'm always running out of space on my mac and there is no cheap way to upgrade that.
hmm, gotta think about this. Two good choices in my price range so far.
dallascaley
Yep, if you only need to record eight tracks and do not need a mixer, then a stand-alone recorder would be the way to go. I have the Zoom F8 and it’s a reliable piece of kit. I’d certainly go for that over Behringer gear.
I also have the Soundevices MixPre eight track recorder, which is a step up again.
Something to consider though, you mention in your original post that you want to record inputs when playing live. Assuming you are amplifying your live gigs, have you thought through how you will split the signals from whatever system you are using for live amplification?
Bob Bickerton
Post by The Korff »
dallascaley wrote:So, the main advantage I can see with this device over the Behringer UMC1820/Mac Laptop setup is that if I wanted to go record a live show I wouldn't have to worry about lugging around my Macbook and worrying about it getting stolen or beer spilled on it...
For clarity's sake, I recommended the UFX1604, not one of the UMC ones. (The UFX1604 allows you to record all the inputs discretely to an attached USB hard drive, sans computer.)
Cheers!
Chris
The Korff
Post by akast27 »
I have been doing some research recently since I also want to record 8 or more tracks at the same time and do this live for gigs, practice, at home and then be able to add more things afterwards like tracks, add more effects, voices, edits etc....
The Tascam SD24 and Tascam SD32 have had good reviews and can:
Record up to 8 Tracks Simultaneously
Records to SD/SDHC Cards (they are cheap and reliable)
Tascam SD 32 model has Up to 32 Track Playback, also 256 Virtual tracks (8 per all 32 tracks -which means you can have 8 individual takes per track and chose which one out of the 8 you like best for your mix)
21 Faders
24-bit/48 kHz Resolution (CD quality, .01 THD)
8 Combo XLR/TRS Mic Inputs
Various edit functions(COPY INSERT, COPY PASTE, MOVE INSERT, MOVE PASTE, OPEN, CUT, SILENCE, CLONE TRACK, CLEAN OUT)
Undo and Redo function with Undo history
8 dynamics effects (good but will not blow you away, you can add better effects to the board if you want).
Built in:
Guitar effects
Mix-down effects
Mastering Effects
Track bounce function
Locate mark up to 99 at one song
File transferring via USB2.0
Chromatic tuner
Metronome (no Drum machine built in)
Has click start pedal to start your recording
The Zoom 24 also has good reviews but the Tascam 24sd and 32SD seems to be rated just a little higher. Zoom has a drum machine built in which is nice for practicing and for creating song ideas. The Zoom downside is that the Zoom 24 does not have a click start pedal to make it easy to start your recording near your instrument and give you more control of punch ins.
I have a great Soundcraft mixer which I love but it takes more time to use with my DAW or to just use only my DAW which I have in my Music room in my basement. I wanted another easy way to record fast with good options for my 2nd music room in one of my bedrooms and I think I have narrowed down my search between the Tascam 32SD ($599) and the Zoom R24 ($499).
There are many other options in the $2k or less range for recording 8 or more tracks at the same time but they are only one take type recording mixers, those boards don't allow you to make any changes or add any tracks and many record the 8 tracks down to 2 (stereo) and then you can transfer the recording to a DAW and add more tracks and mix as you like. But keep in mind that you are cutting 8 tracks down to 2 and lose control of your editing abilities. The Soundcraft MTX 12 ($499) and MTX 22 ($899) allow you to send all 12 tracks and 22 tracks to your DAW individually so you don't lose your editing options. I am extremely happy with my Soundcraft mixers sound, capability and overall quality and highly recommend either of these models if they meet your requirements.
Best of luck and please let us know what you decide and the results your getting.
Best Regards,
AK
akast27
Posts: 1 Joined: Fri Feb 22, 2019 2:21 am
