A while back, I bought a nice outboard compressor via eBay, When I picked it up I got talking with the seller, who gave me a tour of his semi-pro home studio. He played me some tracks he'd recorded (ambient/pop) and I was really impressed by the quality of the vocal sound. He said that he used a dynamic mic (an AKG D330).
So I decided to get something similar and ended up with an AKG D7. This is a live mic (obviously) but what I'm curious about is how best to use it in my own little studio. In most live situations singers will be encouraged to "eat the mic" which makes sense when there's spill, but what about in a studio setting?
The AKG "manual" suggests the following:
Basically, your voice will sound the bigger and mellower, the closer you hold the microphone to your lips. Moving away from the microphone will produce a more reverberant, more distant sound as the microphone will pick more of the room’s reverberation. You can use this effect to make your voice sound aggressive, neutral, insinuating, etc. simply by changing your working distance. Proximity effect is a more or less dramatic boost of low frequencies that occurs when you sing into the microphone from less than 2 inches. It gives more "body" to your voice and an intimate, bass-heavy sound. If you sing directly into the microphone, it will not only pickup excessive breath noise but also overemphasize "sss", "sh","tch", "p", and "t" sounds.• Therefore, sing to one side of the microphone or above and across the microphone’s top. This provides a well-balanced, natural sound
So, what distance/angle are people using with dynamic vocal mics in a studio setting?
What about pop filters?
And shockmounts?
BTW, gain isn't a problem as I'm using it with a McBoost and a WA273-EQ.
Cheers,
Chris
