I know whatever sounds best is the best approach, but I'm curious do most people insert their amp sim then eq's after it or would you eq first?
Looking at my guitar pedal board I have EQs before my guitar goes into my tube amp.
But it sounds a bit un natural when I do this using Eleven for some reason.
and I always put flangers and crazy fx last in the chain.
Amp Sims and order of EQ and plug-ins
- Guest
Re: Amp Sims and order of EQ and plug-ins
The 'traditional' way would be to put 'pedals', including flangers, ahead of the amp, and that's the approach I'd take.
But I would leave delays and reverbs after the amp.
Good spot!
Wonks wrote:Troll/Spammer
Thanks Hugh.
Personally I'm of the opinion for EQ before the amp, and after, much in the same way as you'd EQ a mic coming from the amp speaker
- garrettendi
Frequent Poster - Posts: 3584 Joined: Sat Dec 10, 2005 12:00 am
