Dymo-esque labelling machine/gadget?
Post by baward »
Hello,
Several months ago, I saw a thread which related to some ideas for a studio labelling gizmo. There were some good recommendations (one I think from Hugh R himself) but I now can’t locate it. Search results mostly give info about record labels, not sticky labels...
Does anyone know what I’m going on about? Thanks!
baward
Posts: 431 Joined: Tue Feb 04, 2003 12:00 am
Re: Dymo-esque labelling machine/gadget?
Posts: 43693 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Ad I use something vaguely similar (older version) to this:
Wouldn't be without mine!
Posts: 21435 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
I have the same one as Hugh, it is very good. If you're labelling gear clean the area with alcohol before sticking the label on for best longevity.
edit:- IIRC it will print whatever you copy/paste into the app, even basic monochrome images/logos
Posts: 22910 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by ConcertinaChap »
The Elf wrote:And I use something vaguely similar (older version) to this:
Mine is an older version of this too.This on Amazon is pretty close to it. Cheap on both tape and batteries it gets used all over the place and not just in the studio. Only downside is the arrangement of buttons in alpha rather than qwerty for some reason. Not a showstopper, though.
Last edited by ConcertinaChap on Wed Jul 24, 2019 1:00 pm, edited 2 times in total.
ConcertinaChap
Posts: 15239 Joined: Wed Jul 20, 2005 12:00 am Location: Bradford on Avon
Making music: Eagle Alley
Post by DGL. »
Brother D600 user here, can take up to 24mm labels and as such can take their printable heatshrink. Compatible labels are available and are mega cheap, from ~£3 a cartridge for 24mm laminated from a UK eBay seller.
Has the advantage over some of the cheaper machines that you can either use it stand alone (in which it has a good array of templates (and you can download your own if you want), electrical symbols and has a QWERTY keyboard, plus it works with the PC/MAC as well using the P-Touch software which is really quite good.
DGL.
Posts: 2321 Joined: Fri Oct 28, 2011 12:00 am Location: Portland, Dorset
ConcertinaChap wrote:Only downside is the arrangement of buttons in alpha rather than qwerty for some reason. Not a showstopper, though.
If you want QWERTY then there's this
https://cpc.farnell.com/dymo/s0758380/l ... 20porinter#
Posts: 16990 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by baward »
Wow, many thanks for your replies!
baward
I have used the Brother P-Touch for many years and it is both reliable and cheap on batteries and tape but do go the extra few pounds for QWERTY well worth it for the lack of hassle.
+1 on the alcohol cleaning. This i3 HP lappy now has 25% of the keys overlaid with Dymo letters! Last about six months. (must do T and I again!)
Dave
Posts: 19147 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
