I run a small professional recording studio and the audio interface is an RME Fireface UFX attached to an RME Octamic XTC to allow for all of the studio inputs.
I use high quality mics and cables and preamps etc with PMC TwoTwo 6 monitors and have an acoustically designed mixing room so you'd think that I would be completely happy with the set up, but I'm not because there is something about my mixes that doesn't sound as 'deep/open/expensive/clear' (can't think of the right adjective!) as many professional mixes out there, so I've often wondered about getting a separate A-D converter and whether that would make a big difference to overall sound quality, or whether it's just my skill level?
I am not an expert at A-D. I know why it's important and enough about jitter etc. so with this question I'm really asking:
1. Would a separate A-D converter unit transform my studio recording sound and make it sound more 'expensive' (insert adjective)?
2. Should I actually be dumping the RMEs and getting a completely different interface instead?
3. If the separate AD converter will transform my sound, what converter is recommended? I'd be prepared to pay upto £5k if it will make a huge difference to the sound.
4. How would I incorporate it into the setup with the RME, especially as it's already connected to the Octamic?
5. Do I need just a 2 channel, or do I need an 8 channel unit? I do recording and mixing in the studio and have masters done by a mastering engineer separately.
6. Don't let this sway the answer towards the Dangerous Convert system but I've been reading about the USB back to computer function and don't understand why it's necessary - I thought if you had an AD unit everything would go through that and back into the Fireface to then record and export from the DAW in the upgraded sound quality, wouldn't it? Or am I wrong?
I know that is a lot of questions and I appreciate any and all responses.
Matthew
