Acoustic properties of white polystyrene & higher density hard foam vs Rockwool
Post by Baldo »
Hi,
Can I ask what are the acoustic absorption properties of the Polystyrene panels? These are 600x1200mm panels of various thicknesses from 20mm to 50mm. They use them here as insulation under buildings and on walls.
There are also other hard foam like panels which are not really polystyrene but more of a hard type of foam. I think architects use it for making models and they also use these as insulation in buildings.
How are these materials when it comes to making sound absorbing panels instead of using rock wool or fibre glass? Will they do the job of absorbing the bass frequencies?
Let me know if you need me to provide any more information. If you like I can take pictures and upload them.
Many thanks.
Baldo
Baldo
Posts: 289 Joined: Thu Dec 12, 2002 12:00 am Location: Germany
"Never put a recording studio in your home, it is a black hole into which you can pour unlimited amounts of money" Pete Waterman.
Re: Acoustic properties of white polystyrene & higher density hard foam vs Rockwool
Pretty poor.
Also polystyrene is the worst possible substance to have in your living space. If you are ever unfortunate enough to have a fire, you're dead! No ifs or buts.
Posts: 20882 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Expanded polystyrene is quite good at not transmitting sound, but that's because it reflects a lot back. So quite good for soundproofing and thermal insulation (if enclosed in suitable fire-resistant material), but not good for acoustic treatment in a studio.
As Folderol says, it's a real fire hazard if installed without a thermal barrier for protection.
Any other hard foam is likely to be closed-cell in nature and so, like polystyrene, is OK for sound insulation but poor at sound absorption within in a studio as most sound simply gets reflected back.
You need an open-celled foam, that lets sound waves penetrate right through and get absorbed as they do so.
Also polystyrene is very light, for sound insulation you need mass which it doesn't have much of.
Posts: 22908 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Baldo wrote:Can I ask what are the acoustic absorption properties of the Polystyrene panels?
Next to zero, basically... although I expect they will damp the extreme HF to some extent.
Absorbers work by allowing air pressure waves to enter the material and lose energy by fighting its way through it. Hence the effectiveness of the tangled fibres of mineral wool, or the interconnected open-cells of foam.
If you hold the polystyrene panel up to your mouth, make a seal, and blow, I suspect you won't be able to... demonstrating that sound waves can't enter and no absorption can occur.
Yes, quite good as heat insulators... But not nice should they ever catch fire due to the toxic fumes produced. I wouldn't have polystyrene anywhere in my studio space!
Don't know what that is... but try it with the test described above. If it is porous it might be useful in an acoustic sense... some acoustics foams are fairly rigid...
I'm opting for no... or at best, very unlikely! :-)
Posts: 43693 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by Mixedup »
Folderol wrote:polystyrene is the worst possible substance to have in your living space.
Yeah. You'd be better off covering the walls in diffusion made solely from kindling :beamup:
Mixedup
It's actually pretty hard to set light to. But once it does go, it goes.
Post by Studio Support Gnome »
Both are acoustically useless for absorption or soundproofing.
Both offer good mechanical linkage through rigid light structure , no useful absorption to speak off, either in soundproofing application, or in acoustic treatment.
FR polystyrene is commonly used for diffusors.
RPG's skyline type for example.
that's the limit of it's usefulness in the majority of cases.
(it can also be used in conjunction with concrete pour as a moulding material to produce diffusive structures, and slot absorbers , but that is the realm of the specialist environment )
Posts: 3025 Joined: Tue Jul 22, 2003 12:00 am Location: UK
Mostly Retired from Audio.... If I already know you I'll help,  if not....    Ask Hugh Robjohns, unless that is you're in need of 80's shred guitar... that, I'm still interested in having fun with...
Post by Baldo »
Thanks for this guys.
I shall have to get some Rockwool again and build the bass traps.
Saved me from spending too much time going down a wasted rabbit hole.
Baldo
