I came across these recordings,
https://youtu.be/wPrku3CA2Y4
They sound very spacious on headphones, which is how they are supposed to be listened to. It has a very spacious open feel it.
How can i create this effect for other music tracks that I have. Can I use one of the effects plugins in Logic Pro to do this?
Many thanks
What is the plugin or effects used to create this?
Re: What is the plugin or effects used to create this?
I presume you’re referring to the lead vocal, it has delays and reverbs, I can’t listen in stereo at present but I imagine the effects are widened with plugins such as Logic’s Stereo Spreader and Direction Mixer.
Hi Baldo!
'8D Audio' seems to be a comparatively new craze, but an effective one, and I even found myself donning headphones yesterday to have a listen, and being rather impressed.
There's a nice article here explaining a lot more, although it's careful not a give away many of the so-called 'secrets' other than mentioning binaural audio
https://melmagazine.com/en-us/story/why ... r-8d-audio
The tracks I listened to certainly seem more effective at creating 'behind the head' sounds than any I've listened to in the past, although I suspect part of their secret is that the sound continually moves around, so you anticipate where it's going next.
Posts: 22117 Joined: Wed Jan 13, 2010 8:44 am
Martin Walker wrote: The tracks I listened to certainly seem more effective at creating 'behind the head' sounds than any I've listened to in the past, although I suspect part of their secret is that the sound continually moves around, so you anticipate where it's going next.
Yes... is there a way to use the spatial effects without movement? It does sound quite cool.... back in the 90's I had this box called a Hughes spatial something or other... reminds me of that. But if it has to swim all the time I don't care for it much other than a bit of a gimmick... at least for music production.
_________
David
David
_________
David
David
The 8D examples linked here just make me feel seasick! I thought that sort of back and forth (and behind) panning went out of vogue in the seventies...I must go listen Ummagumma again...
- jimjazzdad
Regular - Posts: 291 Joined: Sun Dec 15, 2013 12:00 am
Halifax, NS, CANADA
