Connecting pedals to iRig2
Post by garrettendi »
Had a chance to play with GE Labs* the new iOS guitar FX app and I like it, but I'd like to use it as a plain amp and use my pedalboard into it.
Said pedalboard has distortion pedals, and I have had problems with howl before, but nothing bad with my UMC204HD interface. And even then it only occurs when I stack multiple high gain pedals in series, which I very very rarely will do.
What should I watch out for when I'm driving say my Behringer HM300 into a high gain amp in GE Labs?
* Basically like Bias FX or Amplitube, but free!
garrettendi
Posts: 3584 Joined: Sat Dec 10, 2005 12:00 am
"The blues isn't about feeling better. It's about making other people feel WORSE, and making a few bucks while you're at it." - Bleeding Gums Murphy
Re: Connecting pedals to iRig2
Post by al_diablo »
Not specific to your setup because I havent used the GE Labs software but I find amp modelling to have a smaller sweet spot regarding input level than real amps, particularly if you're stacking drives. You might find it sounds better to do all your gain on the board and then run it into a clean amp model. If you do decide to use a high gain amp model, aim for a lower gain than you might plan to use from the amp
al_diablo
Posts: 227 Joined: Thu Jul 24, 2003 12:00 am
It's an A/D interface, so you'll need to be careful of input levels to the interface as it's not really designed to have pedals before it. It really expects you to be using all software FX.
You won't damage it with a loud input signal, but you could easily get nasty digital clipping if you don't adjust the input gain to suit, or else keep the pedal output no louder than the bypassed level.
