metronome vst with swing
Post by paleface »
does anyone know of a vst metronome that has swing ?feature
it would be really helpfull
or a way of adding swing to the reaper metronome ?
paleface
Posts: 198 Joined: Thu Jun 12, 2008 12:00 am Location: midlands
Re: metronome vst with swing
You could just record the rhythmic kind of click you want to a MIDI track, set to play a drum sound or synth.
Posts: 21435 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by paleface »
hello elf
i want to keep it simple and be able to do it without
faffing around
i know reaper has the swing option on the grid
wich works great post playing
i just wanted something i could use quickly at the start of a session
that would give me more than just a straight clik
paleface
A metronome implemented as a VST plugin is going to follow the tempo setting of the host DAW. As swing involves a variable offset against a background clock I would be mildy surprised if a VST implements that because it probably wouldn't align that well to the swing-related quantize settings in the MIDI editor or the swing feature on Reaper's grid.
As swing can be applied in varying amounts and is not a known constant, I think The Elf's solution is the most sensible because you can create such a guide track using the swing features in the DAW itself. This will remain synchronised with subsequent edits (such as swing-related quantisation) whereas stuff played to 'external' implementation of swing in a VST probably won't sound as good.
I'm sure it's possible to have a go at it, but if I was developing a metronome VST it's probably a feature I would avoid myself.
Posts: 9978 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Post by BJG145 »
That was a good explanation!
Posts: 8088 Joined: Sat Aug 06, 2005 12:00 am Location: UK
Or if you've got a drum VSTi use that with a simple rhythm and a bit of swing added in the VSTi?
Posts: 29717 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by paleface »
mmmmmmmmmmmmmmm
its still all adding the swing post recording/playing
rather than as
wich is what i really want
paleface
Post by DC-Choppah »
paleface wrote:does anyone know of a vst metronome that has swing ?feature
The problem is that swing feel needs to be inside of (between) the beats. Not on the beats.
Better to record a percussion groove that has the swing feel you want, like a clave, or shuffle beat, and that let the regular metronome play on top of that.
What I do is I always make my own click track track groove for the tune. Generate an even beat groove, then add a swung percussion on top of it. Use that as the click.
DC-Choppah
Posts: 2054 Joined: Fri Jul 20, 2012 12:00 am Location: MD, USA
Post by innerchord »
Unless I've missed something it seems to me as if this is being over-complicated. As per the previous poster, just record a swing metronome and use that. That way you could also have a variety of different swing feels to use.
If your DAW supports it, you can use a swung grid if you want recording to snap to it later.
When I was doing a lot of rhythm programming (a few decades ago) I'd do this all the time, so the click would match the feel of the song, or to suit the requirements of the musician(s) I was recording. I rarely used a built-in metronome click in a session.
innerchord
Posts: 212 Joined: Wed May 11, 2016 12:00 am
