dummy 13a plug with earth
Know what I mean sport?
A plug with no live or neutral connections but a solid connection to the earth pin.
I can find plugs that have a high resistance earth outlet for static control but nothing with a solid earth.
Re: dummy 13a plug with earth
The only one I found was this one from Groundology:
https://www.soundonsound.com/reviews/groundology-earth-connection-plug
Silly money -- because the market it's designed for can withstand it! -- but it is well made.
My inclination would be to make one from a standard plug top. Maybe encapsulate the live and neutral pins internally in epoxy so there is no risk of the earth wire becoming detached and making contact with the live?
I do have slight reservations WRT safety so what does the 'hive mind' think?
Forum Aficionado - Posts: 22907 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Sam Spoons wrote:My inclination would be to make one from a standard plug top. Maybe encapsulate the live and neutral pins internally in epoxy so there is no risk of the earth wire becoming detached and making contact with the live?
Yeah, 'I' could do that but I want the information for a very 'newb' person on another forum and a US (I think) mains supply.
Definitely a 'point him at the Groundology website' situation (assuming they do US plugs).
But, are US mains installations routinely 'grounded'? Outside my experience but if not ...
I did make one for exploratory use, although I consider myself an experienced user. That idea about epoxy is probably a sensible one for general purpose safety though.
Posts: 22577 Joined: Wed Jan 13, 2010 8:44 am
Martin Walker wrote:Sam Spoons wrote:My inclination would be to make one from a standard plug top. Maybe encapsulate the live and neutral pins internally in epoxy so there is no risk of the earth wire becoming detached and making contact with the live?
I just followed Hugh's tip and used a couple of rounds of heatshrink.
Good idea, though TBH you could probably cut the L and N pins off at the end of the insulated part...
Have someone 3D print some dummy live and neutral pins in plastic for the specific plug type and roll your own.
Most plugs, if not all, have removable live and neutral pins, so do that then the earth pin will locate the plug securely. I don’t know why I didn’t think of that first.
You could use the plastic pins from the dummy plug I mentioned first to glue into the holes left by the brass live and neutral pins.
I came here to point out exactly the same thing. It will plug in with just the earth pin. No live or neutral to worry about.
Andy
Andy
Ingenious, and obvious when you say it out loud
Now, the guy Dave is trying to help may be in the US which would change things a little. However I will probably make myself one using that method. I like the extra rigidity having plastic L&N pins would give though they are probably unnecessary.
Just a thought, those flat fronted socket blanks would work but the pins would be a little short.
Yeah, hmm, see I don't really want to suggest the guy MAKES anything because he has no electrical knowledge AFAICT and I am after all suggesting he sticks something in a POWER socket!
Thank you all for your interest and suggestions though.
CPC sell the yellow plastic grounding plugs in different versions, 0 ohm or including 1M Ohm resistor, Stud or binding post.
Somewhat !
CPC are Farnell and might have a USA option in their USA store.
I got "Access Denied" when I tried to look.
Sam Spoons wrote:Now, the guy Dave is trying to help may be in the US which would change things a little.
Somewhat !
N i g e l wrote:CPC sell the yellow plastic grounding plugs in different versions, 0 ohm or including 1M Ohm resistor, Stud or binding post.Sam Spoons wrote:Now, the guy Dave is trying to help may be in the US which would change things a little.
Somewhat !
These days they are very fussy about the browser you use - idiots!
Vivaldi works for me,
- Folderol
Forum Aficionado -
Posts: 20882 Joined: Sat Nov 15, 2008 12:00 am
Groundology don't appear to do a specific USA plug... just an international adapter one which has an mode for the US:
https://www.groundology.co.uk/earthing/earth-connection-plug-ww
I just googled 'ESD strap plug' and various options came up ranging from £4 to £20. Or did I miss something?
Edit.... yes I did miss something... its a US one yer after. That will teach me to read the thread more thoroughly!
- Moroccomoose
Frequent Poster - Posts: 568 Joined: Tue Apr 12, 2011 12:00 am Location: Leicester
Folderol wrote:These days they are very fussy about the browser you use - idiots!
bah !!!!
RS components USA have a thing....
https://uk.rs-online.com/web/p/esd-grou ... s/2877559/
Still a helluva price though !
blinddrew wrote:Martin Walker wrote:Sam Spoons wrote:My inclination would be to make one from a standard plug top. Maybe encapsulate the live and neutral pins internally in epoxy so there is no risk of the earth wire becoming detached and making contact with the live?
I was going to suggest heatshrink, except that the MK mains plugs I tend to use have live and neutral pins that are a firm fit in their sockets, so you couldn't push them back in with heatshrink shrunk onto them.
wireman wrote:ef37a wrote:Know what I mean sport?
What for?
Getting a good earth into a floating system, say a laptop and bus powered interface. It's not a problem if something in the rig has a 'proper' earth, say through an IEC power plug but many laptop PSUs don't pass the earth connection to the computer.
Sam Spoons wrote: but many laptop PSUs don't pass the earth connection to the computer.
Or, if they do, it possibly isn't as low impedance as it needs to be.
Sam Spoons wrote:wireman wrote:ef37a wrote:Know what I mean sport?
What for?
OK, then. I would just look for a plug that is designed so that the end of the fuse connected to the live pin is encapsulated in the plug top when screwed in. The other end and the fuse would not be needed. It would be pretty unlikely for the earth wire to come loose and hit the live but as far as is possible this should be prevented. Covering up with something insulated or using a directly connected ESD plug would also be an option. If the plan is to make a wander lead then it would make sense to use a short segment of full 3-core cable with insulation at the plug end to get good clamping (for plug styles like the MK safetyplug).
