Audio interface help
Post by punkyfish »
Hi,
So have had advice on here about buying an audio interface for my other half but still struggling. Will be using Cubase which I am hoping to get, educational 11 pro. emphasis on quality And budget under £500 if at all possible.
I need:
Midi
ADAT so I can add on at a later date?
2 headphones monitoring things.
Enough inputs and outputs for a band in the future
Balance inputs TRS , no buzzing?
The ability to record an upright acoustic piano with good mikes.
High and low z.
I will be honest, I don’t know any more than that, apart from I need enough gain to run any Mike?
I have been looking at the Steinberg 816c and Focusrite 3 gen 18i20. Focusrite currently offer 25% student discount on any product, Steinberg comes with Cubase AI. Also looked at presonus 1824c. Other half wants to be able to record a full band but I can’t see that happening for quite a while.
Could someone help out with which one would be good for us? Would a smaller interface do, any help would be much appreciated because despite all the help and research I’m still not sure what to choose.
Many thanks,
Alex
punkyfish
Posts: 61 Joined: Sat Mar 16, 2019 11:59 am
Re: Audio interface help
MIDI - do you actually need it on your interface? If you've got older hardware modules only with 5-pin DIN MIDI connectors, then yes, but almost all new synths and master keyboards connect to the computer with MIDI over USB.
If the interface comes with hardware MIDI, then fine, but unless you need it, don't make it a prerequisite. You can always add a cheap USB to hardware MIDI interface later if necessary.
I say that an RME Fireface would fit the bill.
Even the smallest Fireface UCX will do everything you want - and with an RME interface comes TotalMix, which is worth the price alone, IMHO...
Posts: 21435 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by punkyfish »
Wonks wrote:MIDI - do you actually need it on your interface? If you've got older hardware modules only with 5-pin DIN MIDI connectors, then yes, but almost all new synths and master keyboards connect to the computer with MIDI over USB.
Thanks for the fast reply, yes we have old synths with midi, no new synths...yet! :D
punkyfish
Post by punkyfish »
The Elf wrote:I say that an RME Fireface would fit the bill.
Hi thanks for the quick reply, out of my budget I’m afraid.
punkyfish
The smallest £999 Fireface UCX with only 2 mic inputs but somehow can record a full band and also cost under £500?
It's certainly expandable and a lovely piece of kit, but really doesn't fit the requirements as they stand.
Personally I'd be looking at the Focusrite or the Steinberg, and if he's going to be using Cubase I'd edge towards the Steinberg as there's some additional integration there because they're from the same manufacturer.
Posts: 29715 Joined: Sun Jul 05, 2015 12:00 am Location: York
The only way you could go RME within budget would be to go for a Digiface USB and then add a Behringer ADA8200 8 channel preamp/ADC and a separate headphone amp for the second headphone output. You'd probably also need a monitor controller too. I like that sort of modular approach but it may not appeal to the person buying this interface who probably wants something more all in one.
Posts: 16990 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by punkyfish »
blinddrew wrote:Personally I'd be looking at the Focusrite or the Steinberg, and if he's going to be using Cubase I'd edge towards the Steinberg as there's some additional integration there because they're from the same manufacturer.
Thanks, that is what I was thinking, I wasn’t sure if one had better quality or not, the Focusrite 25% discount is very appealing though. I did wonder about the Ur44C as well?
punkyfish
Post by punkyfish »
Thanks James, I will be honest and say I don’t know enough about all the modular stuff and I doubt my husband does hence asking about the all in ones. I notice the dip mentioned a lot for Steinberg and pads on the focusrite but don’t really know what they do.
punkyfish
It has ADAT, so is expandable for that future band requirement - and I had no idea of budget!
I see this is a follow-up to another thread. That's why these things are best kept in one place!
The Elf wrote:It has ADAT, so is expandable for that future band requirement - and I had no idea of budget!
Clearly stated in the OP!
Specsavers time again ? :D
Post by Kwackman »
Just to muddy the waters, there's Audient iD44, but no MIDI. Although you could get a separate MIDI only interface?
EDIT it has only 4 inputs, but I'm not sure how many you need initially?
It has Dual ADAT, so adding on in the future isn't a problem.
Kwackman
Posts: 3687 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Post by Fishnish »
The Steniberg UR 816 or the Focusrite are both of a similar feature set and quality, either will do the job. I'd say that at that price point and given the feature set you'd like they're both good options.
The Steinberg is perhaps marginally easier to set up + use within Cubase as the software which drives it has its controls appearing directly in the Cubase mixer panel. It also has some DSP effects (Digital signal processing - basically an eq, a reverb and a compressor) which can be useful but non essential additions when recording and monitoring whilst recording. The Focusrite, according to colleagues who use it , is also pretty straighforward to set up (although its controls wouldn't appear inside Cubase but in it's own other bit of mixer software) If the Focusrite is currently at a discount price that could be attractive too of course!
If there wasn't too much in it pricewise I'd probs go with the Steinberg for ease of use/integration with Cubase. However If the Focusrite was really significanty cheaper and budget is super tight I might end up going with that.
The Steinberg UR 44c you mention is a good unit too. the main differences between it and it's bigger brother are that it doesn't have as many physical inputs and outputs (necessary if at some point in the future you want to record lots of tracks at once, recording a whole band for instance) and it's not, as far as I know, expandabe via ADAT to give more in/out channels if needed in the future.
Fishnish
Posts: 239 Joined: Fri Dec 24, 2010 12:00 am
Post by punkyfish »
Fishnish wrote:The Steniberg UR 816 or the Focusrite are both of a similar feature set and quality, either will do the job. I'd say that at that price point and given the feature set you'd like they're both good options.
The Steinberg is perhaps marginally easier to set up + use within Cubase as the software which drives it has its controls appearing directly in the Cubase mixer panel. It also has some DSP effects (Digital signal processing - basically an eq, a reverb and a compressor) which can be useful but non essential additions when recording and monitoring whilst recording. The Focusrite, according to colleagues who use it , is also pretty straighforward to set up (although its controls wouldn't appear inside Cubase but in it's own other bit of mixer software) If it's currently at a discount price that could be attractive too of course!
The Steinberg UR 44c you mention is a good unit too. the main differences between it and it's bigger brother are that it doesn't have as many physical inputs and outputs (necessary if at some point in the future you want to record lots of tracks at once, recording a whoe band for instance) and it's not, as far as I know, expandabe via ADAT to give more in/out channels if needed in the future.
UR 44 out! That’s great thanks so much! It’s just a case of which one, as I can get the focusrite for £340 whereas the Steinberg is around £500. So hard to choose when you don’t know all of the things they do but you kind of know what you need?
punkyfish
Post by punkyfish »
Kwackman wrote:Just to muddy the waters, there's Audient iD44, but no MIDI. Although you could get a separate MIDI only interface?
Thanks will have a look!
punkyfish
punkyfish wrote:That’s great thanks so much! It’s just a case of which one, as I can get the focusrite for £340 whereas the Steinberg is around £500. So hard to choose when you don’t know all of the things they do but you kind of know what you need?
If you can get the f'rite for £340 that's a steal. Almost a worryingly low good price - is it definitely a third generation model? Any chance of a link?
Post by punkyfish »
Hi yes see here
https://store.focusrite.com/en-gb/offer ... rrency=GBP
punkyfish
TLDR!
Hi yes see here
Ah, from the focusrite store. Fair enough, I think we can count that as legit! ;)
Personally if I could get an 18i20 for £340 I'd go for that and be a happy camper.
Post by punkyfish »
blinddrew wrote:
Hi yes see here
Thanks, the discount is amazing, wish Steinberg did one for hardware, but I just have a niggle that I should pick the Steinberg...decisions, aargh!
punkyfish
Post by CS70 »
Then stop reading here and go pick up the Steinberg.
It really makes little difference, so trying to decide on facts will get you nowhere. :)
Much better to follow your feeling!
Posts: 7799 Joined: Mon Nov 26, 2012 12:00 am Location: Oslo, Norway
blinddrew wrote:
punkyfish wrote:
blinddrew wrote: If you can get the f'rite for £340 that's a steal. Almost a worryingly low good price - is it definitely a third generation model? Any chance of a link?
Hi yes see here
If you don't have a .ac.uk email you can still find a factory refurb'd Focusrite for £386 at
https://store.focusrite.com/en-gb/categ ... efurbished
FWIW I doubt he will be disappointed with the Focusrite and that difference in price is not to be ignored. :thumbup:
Posts: 22908 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by punkyfish »
Sam Spoons wrote:FWIW I doubt he will be disappointed with the Focusrite and that difference in price is not to be ignored. :thumbup:
Thank you!
punkyfish
