Digital to analog xlr input hum
Hello everyone, hopefully I can find some help on this forum. I have a behringer x32. Using xlr out going to a Mackie analog mixer channel one xlr input. There is a loud hum coming through the speakers. When I unplugged the XLR cable from the Mackie of course the home stops. Any help would be appreciated
Re: Digital to analog xlr input hum
Assuming you're talking about balanced analogue connections between the two consoles, the most likely problem is a ground-loop between your X32 and the Mackie. And the easiest way of solving it is either to connect via a line-isolating transformer box. I like the ART DTI as a value-for money and very versatile solution, but there are plenty of similar alternatives around.
Alternatively, if you fancy some DIY and have don't mind chopping up your XLR cables, then open the male XLR end and cut (and insulate) the cable screen connection to pin 1. You'll need to do that both both XLR cables if you're running stereo between the devices.
Posts: 43690 Joined: Fri Jul 25, 2003 12:00 am
It may also be worth saying that the X32 will be putting out a line level signal while the XLR input on the Mackie will probably be expecting a mic level signal so any slight noise on the X32 output will be heard as a much louder noise through the Mackie.
You probably need to use an attenuator between the X32 and the Mackie to match the signal levels.
Posts: 16988 Joined: Mon Sep 10, 2001 12:00 am
Or, better still, an XLRF to TRS cable to let you use the 'P48 safe' line input most Mackies have next to the XLR mic input.
Forum Aficionado - Posts: 22904 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
