Live. Studio. Don't care. If it's clean, I end up drawn to it like a moth to flame.
But how many know that it's not the easiest thing to pull off... especially of you aren't in the most conducive of environments.
So these are some of my rules of thumb to a clean mix... PLEASE... and I mean PLEASE... share your tips to getting a mix squeaky clean!
• Garbage in, garbage out
• the "pause" or the "lock" - one time I did a rough mix in my masterclass and the tone was IMPECCABLE. Tone is everything in the studio. I said "let's mix it"... but this knucklehead didn't hear what I did! So he started over from the top... when the drums were already clean
• Picturing the statue at the marble stage. Whether it be EQ, or Compression... I've got to see how it COULD be clean before I make mixing decisions.
• Isolation. Not location... but frequencies. This is how its done! If you get every single instrument in its own pocket in the spectrum, the mix will have POCKET... and it MIGHT be clean. Whatever tool is necessary to make it happen... use it.
• Warmth usually mean im done. Im always tryna get my final mixes and masters warm. On all records I've heard that are truly great... the sounds were made to work together in a way that added to the others. Everything was EVENTFUL... everything was made to be there!
I could go on... but I wanna hear from the community...
How do you make consistency clean mixes??
Sent from my SM-N970U using Tapatalk
