How to connect a Behringer EQ to mixer and speakers.
Hello everyone,
I am setting up a basic system for my band's rehearsal/performance space aka the basement!
We have a Mackie profx16v3 mixer and a Behringer FBQ3102 2 channel 31 band EQ. The signal from these units would go to a couple of Carvin powered speakers for mains and a powered monitor.
I am trying to figure out the best way to integrate The EQ in. I'm wondering if I could use one channel of the EQ for the mains and the other for the monitor and how to wire them. Feedback is a major concern and it would be nice to use the feedback detection in the Behringer to help control the trouble frequencies in both the mains and and the monitor.
One wiring set up I was thinking of would be one TRS cable from an aux out on the mixer going to an input on the EQ and then out from EQ to monitor. But I'm not sure how to connect the mains. The left and right outputs on the mixer have both TRS and XLR. If I keep my channel pans all at 12 o clock and connect a TRS or XLR cable to one main output of the mixer then onto the second input of the EQ would that work as a balanced mono connection?
But what if I wanted keep a stereo mix for the mains in the above scenario. Could I use y cables from the mixer outputs to the EQ and then a y cable out of the EQ to the L and R main speakers?
Any input or insight to my set up would be greatly appreciated!
Re: How to connect a Behringer EQ to mixer and speakers.
TM68 wrote: ↑Mon Oct 11, 2021 11:42 pm
This will work
This will not work
- resistorman
Frequent Poster - Posts: 2905 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
You need 3 channels of eq to do that, and you have only 2. For the situation you are talking about, I would just do mono mains anyways!
- Funkyflash5
Regular - Posts: 215 Joined: Thu Apr 26, 2018 12:43 am Location: Wisconsin, USA
If you aren't using all the channels on the mixer you could assign all your instrument tracks to a sub mix and then send that sub mix to the one side of the eq eq and return it in to mixer on a free channel. This channel is then routed to the main L-R out.
This means you eq for the instruments on the mains and you can still run a stereo track that is routed straight to the L-R outs that bypasses the trip through the eq.
Leave yourself plenty of headroom as getting the gains in the right places is important as you could easily end up distorting the signal if you aren't careful.
Mono all the way, live, stereo is wasted, in my experience, I’ve never used a stereo rig at any gig.
Gristleize!
Agreed - in my head was the potential advantage of running in between set tunes and a post performance disco without having to sum the tracks to mono or losing a channel.
The two channel of the EQ can be used independently, so you could use one channel to control a single monitor speaker, and the other channel to control a mono mix from the console to feed both FOH speakers.
Yes... but see below.
Yes.
Then you'd need to use both EQ channels for the FOH speakers, one for the left channel between mixer and left FOH, and the other for the right channel. If you still need EQ on the monitors you'll need additional equaliser units.
No.
If the main purpose is controlling feedback it is better to have one EQ channel per speaker (each Foh and monitor speaker) since their different physical locations typically cause different feedback frequencies.
Posts: 42579 Joined: Fri Jul 25, 2003 12:00 am
I used to be 'mono all the way' but I'm now more of a 'narrow stereo' sort of guy (pans set 10 o'clock to 2 o'clock type range) to seperate things a little, but only if the venue allows. I've played plenty of pubs where you're in the corner of an 'L' shaped room with a speaker firing down each leg and not a single person able to hear in stereo.
For the most part having two PA cabs is more about coverage than stereo. Stereo in-ears though are another matter all together.
- Music Wolf
Posts: 2874 Joined: Fri Feb 17, 2006 12:00 am
No One There
https://www.starbelly.me/
Music Wolf wrote: ↑Tue Oct 12, 2021 2:24 pm
I always give a mono feed, I’m scared of stereo sounds suddenly disappearing to another side of the room, and the audience becoming very confused, but that’s just normal anyway, at one of my gigs.
Gristleize!
I always send stereo to FOH, and then it's up to them. When I have asked them most seem to run stereo, which is what I would prefer.
Swishy chorus on acoustic guitar and short, slappy delays on vocals work well in stereo without the potential mono pitfalls.
If you have 1u rack space spare there are many useable 2ch EQ units available for pennies these days, you'll always find a use your new spare channel.
- shufflebeat
Longtime Poster - Posts: 9830 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
With proper mic placement and sane levels you may not need eq on the mains. Plus there are EQs on each channel. TBH, those anti feedback EQs are not all that great in my experience, you’re better off setting up and using the PA properly.
- resistorman
resistorman wrote: ↑Tue Oct 12, 2021 10:48 pm With proper mic placement and sane levels you may not need eq on the mains...
Possible but unlikely.
Granted that this is for a static set-up, but in my years trotting around providing live-sound for the same guy in multiple venues I don't think I ever experienced a venue where I didn't have to tune the system to the room.
And while I'm here... my rig had six channels of graphic EQ. Two for mains; four for 4 separate mono monitor mixes.
... and the aforementioned 'guy' always wanted stereo FoH because of the effects he used. Most places could easily reconfigure to stereo if requested (although they were usually mono). The exception was a large town-hall venue in one of Britain's largest cities that said they were only wired for mono; stereo was simply not possible.
- Mike Stranks
Jedi Poster - Posts: 10586 Joined: Fri Jan 03, 2003 12:00 am
