Do you know a good compressor for the Fender American Deluxe Guitar?
Post by joneyjey@gmail.com »
Hi!
I play in a cover band and our genres are famous pop, pop-rock and even some house music. The guitarist has the Fender American Deluxe version.
He wants to find a compressor pedal that could delicately handle the dynamics without squashing it, but at the same time compress it neatly. Mid-range budget.
Any suggestions?
joneyjey@gmail.com
Posts: 22 Joined: Fri Feb 19, 2021 11:38 pm
Re: Do you know a good compressor for the Fender American Deluxe Guitar?
Compression is a personal thing and what one person loves, someone else may find wrong for them. So you’ll probably get several answers that suggest compressors with quite different sounds if you compared them side by side.
I’d highly recommend a low-budget mini- pedal, the Donner Ultimate Comp. I think it’s brilliant for giving a very subtle compression that doesn’t sound like it’s doing anything to the sound until you turn it off and realise it’s doing a lot. Very transparent until you turn the compression right up, where it will give a more standard squashed sound.
Amongst many others I’ve got a Fender custom shop Strat and a Two Rock amp and am more than happy to use this £30 pedal with £5k+ of guitar and amp.
My other compressor is an Xotic SP compressor, which is nice but I don’t like it as much as the Donner. On anything but the low compression setting, it gets far too squashy for me and becomes a specific sound effect rather than an overall levelling tool.
Posts: 18696 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Post by al_diablo »
I have a boss CS3 that can get pretty extreme but used carefully you can use it fairly transparently.
al_diablo
Posts: 227 Joined: Thu Jul 24, 2003 12:00 am
Post by Murray B »
Personally I use a BBE Main Squeeze that makes a sound I like and I have a Modded Boss CS3 that is pretty transparent with the mod but I prefer the BBE.
This site is a pretty good resource for getting accurate reviews of a lot of the available options, but note that the reviewer is considering the use for a bass guitar rather than a 6 string.
http://www.ovnilab.com
There is definitely an argument for starting with the low cost units and working out if you want something that colours the sound or stays transparent.
Good luck
Murray B
Posts: 445 Joined: Mon Nov 28, 2011 12:00 am Location: Staffordshire
Post by djangodeadman »
The Boss CP-1X is very good.
djangodeadman
Posts: 363 Joined: Tue Feb 18, 2003 12:00 am Location: Brighton
I’m not a guitarist, but I know friends who have "not been unhappy" with this,
https://www.andertons.co.uk/wampler-eg ... gLiu_D_BwE
It’s very nice, not intrusive, but can be if you want it to be.
Posts: 20864 Joined: Sat Jul 12, 2003 12:00 am
Gristleize!
I use compression on bass but almost never on guitar (only in stuff like Nile Rogers funk or Albert Lee chicken pickin'). I prefer dynamics to come from how you play. I don't play strict covers though where the sound needs to be as close as possible to the original.
Posts: 22219 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by Random Guitarist »
Mooer yellow comp here. Pretty cheap but gets left on a lot of the time, makes a difference but isn't too overt.
Random Guitarist
Posts: 1170 Joined: Tue Apr 01, 2008 12:00 am Location: West Sussex UK
Post by Murray B »
Arpangel wrote: Fri Dec 24, 2021 9:49 am I’m not a guitarist, but I know friends who have "not been unhappy" with this,
The blend control looks like a particularly useful feature - not something you see on many pedals.
Murray B
Post by AMOS63 »
TC Electronic Hyper Gravity
AMOS63
Posts: 55 Joined: Sun Jul 21, 2019 7:44 pm Location: Bourne, MA USA
I just have one of these: https://www.gear4music.com/Guitar-and-B ... Pedal/1IQV
But I'm not really a guitarist.
I actually bought it to use with a Electro-harmonix B9 but I just tend to leave it on all the time now.
Posts: 28834 Joined: Sun Jul 05, 2015 12:00 am Location: York
Guys! Thank you so much for your experience!
joneyjey@gmail.com
Post by resistorman »
Murray B wrote: Fri Dec 24, 2021 4:13 pm
Very true.
resistorman
Posts: 2929 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
blinddrew wrote: Fri Dec 24, 2021 8:37 pm I just have one of these: https://www.gear4music.com/Guitar-and-B ... Pedal/1IQV
That’s a great suggestion, on every level, simple to use, small, and the price too!
Gristleize!
Post by GCKelloch »
For a lot more money, you might consider either of the audio transformer-loaded Bogner compressors. Transformer saturation is used to control the compression in way other components can't achieve. The release adapts to the guitar transients, releasing quicker when triggered by lower level transients. That gives it an overdriven tube amp feel, but without distortion. They are considered compressors for those, like me, that don't like compressors. The Harlow is ~$180. It's simple, but has a spongy feel you just won't find in other compressors. The more expensive Lyndhurst has more dynamics control options and EQ "make up" settings.
GCKelloch
Posts: 33 Joined: Fri Jul 23, 2021 6:58 am
