Weller Soldering Iron
Post by GRAHAM99 »
I have bought for a few quid in a cash converters a Weller soldering iron.
It says on it Weller TCP 24v 45w.
The lead on it has a blue and brown wire at the end but I take it it would be wrong to just put a plug on this and plug it into the mains?
Does it need a transformer?
GRAHAM99
Posts: 278 Joined: Fri Nov 15, 2002 12:00 am
Re: Weller Soldering Iron
DON'T DO THAT
It's a 24V iron so needs at least a transformer.
Posts: 19728 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
You definitely don't want to put a mains plug on it, you'll destroy it for sure and quite possibly kill yourself in the process.
I sounds like it's designed for use with a solder station but I may be wrong about that.
Posts: 21546 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by Pippacairn »
Hi,
This model is designed to connect to a soldering base station, as new they are supplied with a Bulgin type connector to suit.
Do not connect to the mains under any circumstances.
Pippacairn
Posts: 27 Joined: Tue Mar 09, 2021 6:00 pm
Post by DGL. »
Also the temperature setting is done by changing the tip, using a magnestat to control the temperature. If you do get a transformer (24V 50VA should do i think) and the iron dosn't work then a failed magnestat is a common issue.
DGL.
Posts: 2157 Joined: Fri Oct 28, 2011 12:00 am Location: Portland, Dorset
Post by GRAHAM99 »
I don’t think this should have been sold like this as it really looks as though it just needs a plug attaching!!
Good job I asked….
GRAHAM99
Well, replacement irons are available on their own, but its not usable without a suitable transformer base station (eg. P-51)... which are also available...
Posts: 41744 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Hi Graham, I looked after about 100 of these for the best part of five years and there are several traps for the unwary, firstly of course NO NOT apply the mains to it!
Has it got a tip? If so it must have the retaining sleeve and this is secured at the base by a knurled collar or, on earlier ones , a nut shaped collar. This should only be finger tight but rarely are! Use pliers if necessary but once you get it started try to finish removal by hand, if the tube gets crushed you will have problems.
If you get the tube off, the tip will be retained lightly by the magnetic switch and so push the tip down and you should feel light spring pressure, but not end of world if stuck. If a load of white powder comes out the heating element is surely toast. You can get all the parts for these irons but further work is quite tricky and the parts quite expensive so, up to you how far you want to go. (Cooper Tools used to be the agents in UK)
As said, the iron runs on 24V AC but they are not fussy, have run one on a car battery, just takes longer to reach operating temperature so any odd supply you have around that can deliver 12 to 25 V at 2 amps or more will serve. The tip will have a number on its base. 7 is ok for Lead solder but 8 will be needed for Lead free and then only for relatively fine work. A number 9 will be a whizz on Pb free but take care, they are close to the ignition point of paper!
Tip, don't clean with damp sponge as used to be supplied. Brass wool or kitchen paper.
Posts: 17905 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Post by GRAHAM99 »
Hi Dave
Many thanks for this.
The iron is just as you have described with a 7 on the base of the tip.
I have always wanted a Weller soldering iron but don’t do enough soldering to really justify the cost!!
I only paid three quid for this in a cash converters shop but luckily I saw the 24v on the base,I was just about to put a plug on it,it looks as though it has been prepared for a mains plug!
It came in a Cooper Group cardboard box.
I have a transformer which looks like one from a train set which gives 16v at 14va but I doubt this would be ok?
Could I just buy a suitable adapter without going to the expense of a proper Weller one?
Thanks again
Graham
GRAHAM99
Post by GRAHAM99 »
Can the power supply be dc?
Bit of a novice with this stuff!
GRAHAM99
GRAHAM99 wrote: Wed Jan 12, 2022 9:45 pm Can the power supply be dc?
Never had a problem with it. You could first cold check, the resistance should be about 12 Ohms maybe less stone cold. If it reads O/C bounce it on the tip gently, the switch may have stuck. N.B. They will read O/C without a tip.
You can use any supply less than about 25V to test it, you might bugger the supply, won't do the iron any harm. Got an old laptop charger around?
If the iron works you can order a 24V/2A toroid from RS comps say. Note, even if the transformer does not require an earth the case should be and the iron tied to the earthed case with a resistor of about 100k for static protection.
Post by Mike Stranks »
GRAHAM99 wrote: Wed Jan 12, 2022 9:21 pm
Correct.
I think we need to unpack this stuff about power-supplies a bit more...
Dave has suggested that a 24volt, 2 amp supply would suit. That's 48 va (watts)
He's also pointed out that he's used a car battery for such duties in the past. That's a notional 12volts DC, so you need 4 amps to reach the 48 va. Fortunately a car-battery is quite capable of delivering such currents.
The crucial thing with any power-supply - mains/transformer or battery - is the current they supply. Matching the voltage is fairly straightforward, but the supply must be able to supply the required current.
So... looking at your existing transformer... we're good on the voltage as Dave has said that 12 volts is adequate. However we're way down on current... the device you specify is only capable of delivering 14va - 0.875 amps - way down on the 3 amps that would be required with a 16-volt supply.
Just a final note... the rated va/amps/watts of a supply is the maximum it can deliver. So a 5 amp supply with something that needs 1 amp is fine. OTOH a 1 amp supply with something that needs 5 amps will end in tears...
Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
Can I just point out that it's going to be much easier to buy a cheap temperature-controlled soldering station than faff about with trying to rig up a power supply for a fixed temperature iron that may not even work to start with. Unless you are going into manufacture, then you don't need anything too sophisticated. Like guitars, it's nice to have a custom-shop Les Paul or Fender, but the basic Squier and Epiphone versions still get you most of the way there.
Put the £3 spent down to experience.
Posts: 17931 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Post by MarkOne »
Wonks wrote: Thu Jan 13, 2022 11:06 am Can I just point out that it's going to be much easier to buy a cheap temperature-controlled soldering station than faff about with trying to rig up a power supply for a fixed temperature iron that may not even work to start with. Unless you are going into manufacture, then you don't need anything too sophisticated. Like guitars, it's nice to have a custom-shop Les Paul or Fender, but the basic Squier and Epiphone versions still get you most of the way there.
^^^ This.
I had a Weller for decades but year before last the power supply gave out on it. I didn't even look at getting a replacement PSU (well over £100) For the limited amount I do these days I opted for one of these https://www.amazon.co.uk/dp/B07X3CZ3FJ/ ... UTF8&psc=1 which I think I got it on a Black Friday deal for well under £40, and it's fine. Works pretty well, actually.
Just think of it this way. You could probably have spent more on a Latte in a boutique barista or a large Pinot Grigio , or something equally temporary or disposable. :thumbup:
MarkOne
Posts: 2988 Joined: Thu Feb 15, 2007 12:00 am Location: Bristol, England, Earth, Perseus Gap, Milky Way
My Music on Apple Music
My Music on Spotify
PRACTICAL as ever Wonks! Maybe Graham just wants a bit o fun and messin?
You are quite right. Google will give you many options for T controlled stations. I had a "Duratool" one for some years (I had run out of Weller spares for free!) That eventually broke now use a "Yihua" 937D. Neither as good as the maganastat but very serviceable and WAY better than the ancient Antex!
MarkOne wrote: Thu Jan 13, 2022 11:19 am
^^^ This.
Yes, yes, ALL very logical (but not very green) but some of us LIKE 'king about with stuff and have odd transformers and PSUs kicking about.
Post by GRAHAM99 »
The iron has a resistance of 13ohms.
I have a power supply rated at at 18.5v and 3.5a dc
The input says 240v and 1.5a
I think it is off a laptop so should be ok?
I do like messing about with this stuff!!
GRAHAM99
GRAHAM99 wrote: Thu Jan 13, 2022 6:38 pm The iron has a resistance of 13ohms.
Yeah give it a go, don't burn your fingers!
Post by GRAHAM99 »
Just tried it and the iron got hot!!
Will try soldering with it later.
Thanks for all your help on this.
Could be a good three quids worth!
Just need to rig up something permanant between the power adaptor and the iron.
GRAHAM99
GRAHAM99 wrote: Fri Jan 14, 2022 10:30 am Just tried it and the iron got hot!!
Good oh! Now you have it cooking, bit more distilled wisdom! The best way to clean the bit if it is blackened is to get the iron up to temp and try to melt some solder with it, keep wiping with kitchen paper or cotton (not wool or plastic!) cloth and it should get clean. If not, the very lightest rub with wire wool or you can buy a tip cleaner paste. Works a treat but is pretty aggressive and will wear through the iron plating eventually rendering the tip U.S.
If you start working the procedure as told to me by Weller technical chaps is. "Tin tip, wipe, tin again, solder and when done, for a bit, tin and leave. Before you shut down, wipe the tip and flood with solder, leave to cool. This all will prolong the life of the tips especially the very fine ones. Don't leave the iron cooking all day! It only takes 30 seconds or so to get to op temp so switch off when having a break.
I 'might' have some spares, will let you know.
Post by GRAHAM99 »
Got it melt some solder!!
I have rigged up an old guitar footswitch with a socket for the laptop power supply plug and a jack socket for the the iron.I have put a jack plug on the wires coming from the iron.
I think the temp controll works by the properties of magnets at different temperatures?
GRAHAM99
GRAHAM99 wrote: Fri Jan 14, 2022 5:13 pm Got it melt some solder!!
Yes the Curie point. The magnet is in the tube in the iron and the base of the tip made of a ferrous alloy that loses its magnetic properties at a certain temperature. Clever or what?! Very little to go wrong. Yes, the switches do fail but only after maybe a million cycles. The heating element, because it is low R and robust hardly ever fails. In fact most of the irons I junked were buggered by Homo sappy!
Post by GRAHAM99 »
I tried using the Weller iron to remove a jack socket from a guitar but it would not melt the solder.The tip is a number 7.
I then tried my other “cheap” iron which did melt it.
The Weller will melt some lead free solder I have.
Should I get some other tips for the Weller?
GRAHAM99
Lead-free solder has come in quite a few varieties in the past. Current lead-free solder is quite workable compared to some older stuff, which often needs much higher temperatures and the addition of flux or more lead-free solder to start the melting process. I’ve come across one lead-free joint that I had to adjust my temp-controlled iron to maximum for, before it melted.
In addition, your iron with that PSU has approximately a 26W output, so is running at 57% of its nominal 45W rating.
It’s probably a combination of things.
