... for figuring out what's going in and out of midi-capable boxes?
Or is there anything newer (better?) on the market?
Needs to be windows-based for me.
Gracias.
Is Midi Ox still the thing...
Posts: 27697 Joined: Sun Jul 05, 2015 12:00 am
Re: Is Midi Ox still the thing...
...yes, Midi-Ox never goes out of fashion.
I don't know if there's something newer and/or better but I use MIDI Ox when I need to, and it works fine for me!
Posts: 9551 Joined: Wed Sep 01, 2004 12:00 am
Ditto to the other comments, but I would add
https://www.bome.com/products/sendsx
as a useful little utility. It will monitor incoming MIDI on a given port as well as send out Sysex etc. Not as comprehensive as MIDI-Ox. but sometimes its simplicity is all that is needed. I seem to recall it is easier to copy/paste code from/to the windows as well, if you want to keep a text record. Worth a try.
Thanks all!
Yes, I still have MIDIOX permanently plumbed into my setup to massage the velocity/channel MIDI data from two controller keyboards (one 2-octave one and the other an 88-key master keyboard), combine them and then send them to my DAW.
Like BillB, I've also used sendsx on occasion for sending/receiving simple sysex patch data, but MIDIOX can do this as well, and nowadays many synths have dedicated 'program manager' utilities to do this, without needing esoteric buffer size adjustments.
Posts: 21476 Joined: Wed Jan 13, 2010 8:44 am
For MIDI troubleshooting, and Sysex transfers, it's all about Snoize for me (Mac):
https://www.snoize.com
Everything else I can do in Logic, including programming MIDI tools with Scripter.
muzines wrote: ↑Thu Jan 19, 2023 2:41 am For MIDI troubleshooting, and Sysex transfers, it's all about Snoize for me (Mac):
Hi, I wanted to know how long this program takes to set up? I am very curious to know. Thanks
- Guest
I'm not sure what you mean by "set up"? There's nothing to set up - you run it, send sysex to it and it records it, load a syx file to send it... It's a pretty simple utility.
