Daisy Chaining MADI devices
Post by jaminem »
Hi there, QQ on MADI.
I currently have an RME UFX+ and a Ferrofish A32, if I wanted to add another MADI converter Is it as simple as the following:
Current: RME OUT > A32 IN, A32 OUT > RME IN
Additional converter: RME OUT > A32 IN, A32 OUT > New converter IN, New Converter OUT > RME IN
Guess I'll need single MADI cables rather than the paired one I use now?
Anything else to consider?
Elf you have a similar setup I think?
jaminem
Posts: 1541 Joined: Mon Mar 19, 2001 12:00 am
Re: Daisy Chaining MADI devices
You need to make sure your new converter can be configured to fill the vacant channels in the MADI stream, so 33-64 if the Ferro is using 1-32.
Correct clocking between the converters is also essential, of course.
Posts: 43696 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Yep, you've got it.
I don't recall how I set the second converter up to be channels 33-64, though. I set it up years ago and forgot it was there. That's the joy of the A32s and an RME interface, I suppose! :lol:
I'm sure it's in the manual somewhere.
EDIT:
Hugh, I think the clocking takes care of itself, but again the memory is misted. I can see I have no additional clock cables between my interface and A32s, so it's probably just a parameter thing at most.
Posts: 21437 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
MADI carries embedded clocks, so depending on the system there may be no need for external word-clock cables. However, setting the clocking parameters for each converter is critical for the system to work.
Post by jaminem »
Nice one chaps thanks, I have a master clock is it'll be word clock off that, so not to worried about that bit.
One other Q, if I went for an A16 I assume I can daisy chain another one later if I wanted to add the final 16 channels?
jaminem
Sorry, can't help on the A16 - it's many years since I used one.
jaminem wrote: Tue Apr 18, 2023 12:09 pm
The A16 has been replaced with the Pulse 16. Up to four Pulse 16s can be chained to access all 64 MADI channels. If I recall correctly, you need to configure the unit with its position in the chain (1 to 4) as the MADI conversion imposes a 2 sample delay, so the unit needs to know how many units are in front of it so it can introduce the appropriate synchronisation delay.
Post by jaminem »
Lovely, yes I meant Pulse 16, so in my case the chained Pulse 16 would be device 2 and another would be device 3, thereby giving me access to all 64 channels.
Thank you gentlemen
jaminem
Post by jaminem »
Ah actually just checked, this is not right. The A32 only allows delay compensation for 2 devices not 4, so I guess this means I can have 1 Pulse 16 as device 2, or 1 A32 as device 2.
I'll keep saving then....
jaminem
Post by Matt Houghton »
I believe the Pulse 16 (like the A16 before it) also acts as an ADAT<>MADI converter, and an ADAT<>Analogue converter. So if you were to need further expansion, then I think you should be able to hook up an ADAT converter to your Pulse to give you your 64 channels of MADI<>Analogue conversion in total.
Matt Houghton
Posts: 1603 Joined: Wed Aug 08, 2007 12:00 am
SOS Reviews Editor
jaminem wrote: Tue Apr 18, 2023 1:36 pm Ah actually just checked, this is not right. The A32 only allows delay compensation for 2 devices not 4...
Yes, because it handles 32 MADI channels, so there would only be two units in the chain.
I believe the A32 MADI latency is 3 samples... just to be awkward
I don't see why you couldn't configure the Pulse units as 3/4 in the chain. You'd just need to be aware of a one sample delay/offset between MADI channels 1-32 and 33-64 -- so don't put a stereo array across channels 32/33! Other than that, it should work fine.
But it might be worth dropping Ferrofish a note to ask their advice.
Post by jaminem »
Just to circle back round incase anyone does a search, I have spoken to Ferrofish - they say it can be done!
jaminem
