old converter to computer - how?
Post by heavenorlasvegas »
good evening yall..
i'm looking to test out some vintage converters but it seems that most are just that... converters only, not interfaces.
what in your opinion would be a good route in getting these signals through the converter and into my daw? and also, I dont want an interface to impart any sound to the conversion, I want the converter to be the last part of the chain before it hits my daw.
thanks again.
heavenorlasvegas
Posts: 175 Joined: Mon Feb 22, 2021 2:41 pm
Re: old converter to computer - how?
Post by Matt Houghton »
Let us know the make/model of converter and the computer (Mac/Windows, which version) and we can probably help you figure it out. (But the answer may be as expensive as just buying an affordable modern interface, which probably performs better!)
Matt Houghton
Posts: 1603 Joined: Wed Aug 08, 2007 12:00 am
SOS Reviews Editor
Post by BJG145 »
Matt Houghton wrote: Fri Sep 01, 2023 9:08 amthe answer may be as expensive as just buying an affordable modern interface
Very likely. Still, if you want to experiment...
Posts: 8088 Joined: Sat Aug 06, 2005 12:00 am Location: UK
A/D converters must output some kind of digital format and no interface should colour a digital input so you just need an interface that can accept that format.
Posts: 22911 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
heavenorlasvegas wrote: Fri Sep 01, 2023 6:24 amI'm looking to test out some vintage converters but it seems that most are just that... converters only, not interfaces.
So much information carried in a name... :lol:
A DAW interface with the appropriate digital interfacing to match that of your converter.
Fir example, if your converter has an ADAT output, the RME Digiface USB is a great option. I use an RME AIOPro internal interface card which accepts AES, ADAT and SPDIF from external converters.
Any DAW interface with a digital input simply passes the audio data. It can't alter the sound... but make sure you understand the requirements for proper clocking of the converter / interface and configure the system appropriately.
...and finally, as said above, unless you already have a DAW interface with an appropriate digital input, buying something to work with a vintage converter will probably cost more than the converter, and its own converters will almost certainly perform better.
Posts: 43701 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Thank you all for your suggestions and information. I have opened a new thread relating to this one. Feel free to chime in again with your knowledge. It is very helpful and greatly appreciated. Thank you much.
heavenorlasvegas
Post by BJG145 »
