A pretty common synthesizer sound that’s pretty much a filtered arp..? Recreating it seems pretty trivial, I’m more curious about if this is a common preset/setting on some of these 80’s era synths?
A couple examples, both start fairly early on in the track -
the Cocteau twins one sounds like a pro one but could be anything. The Prince joint is much newer. Could be anything. Both are 1/8th note. 1000 ways to skin this cat.
Cannot think of what waveform, maybe try triangle first as a guess. It will be about getting the right filter action which does not open much and of course playing those notes. There might be a tiny bit oscillator sync going on.
Also the right filter character, it is almost but not quite approaching a vowel type sound (whirr) so the resonance will be important. (has a touch of overtone singing cadence as we discussed on here before so fairly high resonance so some upper partials are exposed a bit.)
Try a Moog (ANA2 has a moog like filter) or something like The Legend, Lu-Sh-101 or Diva, Repro-1 as in the box starting points.
Some sounds that are quite plain are deceptively tricky to synthesize. Get the note sequence right, just an analogue mono synth should do this, either actual or softsynth.
I also loved the Cocteau Twins and Harold Budd album, very dreamy.
FrankF wrote: ↑Fri Oct 04, 2024 1:50 pm
The Cocteaus ditty sounds more like Robin Guthrie's guitar to me, with a slicer or filter arp effect, not unlike How Soon is Now?
Thanks! Will try it one of these days. Was hoping for some old head to tell me “oh that’s just preset D3 on a Juno 60 with the onboard arp set to blah and the filter set to bleh, everyone overused it”
yeroc wrote: ↑Fri Oct 04, 2024 4:48 am
The Twins say often that they didn’t use synths, a lot of their sounds were made with guitars put through drum triggered filters and delays from a Lexicon PCM70.
If you want to have a go on a synth, the triangle was a reasonable starting point guess for synthesizing something similar to guitars.
Good luck with it. I would have a go myself but our music making room is temporarily out of use. Let me know what synths you have and I may still have a go when that room is not inhabited by someone with Covid.
yeroc wrote: ↑Fri Oct 04, 2024 3:23 pm
Truly unbeknownst to me, apparently it very well could be Prince sampling CT’s 50-50 Clown. Hilarious. Maybe not so common of a sound after all.
Arpangel wrote: ↑Sat Oct 05, 2024 7:59 am
SafeandSound Mastering wrote: ↑Sat Oct 05, 2024 10:13 am
Two beautiful tracks. Although I did not try and exactly duplicate the sound, starting with a harmonically complex waveform in my Hydrasynth and assigning the harmonic mutant to that oscillator seems to get me in the ballpark, so that'd be a starting point. Possibly using the vowel filter and sweeping cutoff would also get there, or a combination of these.
