I am running two TRS lines to a Soundcraft UI24r from my Mackie ProFX12v3+ personal mixer, both at line level: one is the mono output originating from my keys, and another is the vocal. The Soundcraft UI24r feeds the FOH PA.
I've learned (from Hugh!) that if phantom power is inadvertently enabled at the Soundcraft UI24r channels my cables happen to be plugged into, my Mackie mixer could get fried, and the best thing for me to do prophylactically is to use a DI box. I know phantom power can be applied to the Soundcraft UI24r XLRs, and in an overabundance of caution I'm also assuming it can also inadvertently be applied to the TRS inputs as well (is that incorrect?). I should note I'm not in charge of the Soundcraft, but even if I were I wouldn't trust myself to not make a mistake.
I have one new Radial Pro D2 box, and after looking it over and reading the information available, I'm not quite sure how to use it
Can someone give me some guidance please?
1. Would I need two Radial Pro D2 boxes, one for the keys, and one for the vox (or can one box be used for both)?
2. Clearly I need to engage the "Ground Lift" button(s) if I want to protect against phantom power running from the Soundcraft UI24r back into my Mackie ... right?
3. Are outputs of the Radial Pro D2 "THRU" and "XLR" still at line levels after the "Ground Lift" button is engaged?
4. Should I use the "THRU" ports or the "XLR" ports to route signals from the Radial Pro D2 to the Soundcraft UI24r? I'm guessing the "XLR" ports, since that's where the "Ground Lift" button is physically located ... ?
5. Do I actually not have to worry about phantom power inadvertently being applied to TRS lines running from my Mackie mixer in to the Soundcraft UI24r ... or is phantom power only able to be applied at XLR inputs on the Soundcraft?
6. I think I've read (but can't find that again to confirm, so maybe I just misunderstood) that ground lifting can affect the actual tone of the signal coming out of the Radial Pro D2 - is that a thing, and should I be concerned, or is it only hypothetical?
Sorry for so many questions ... I am so inexperienced here, in my last band I think we just all "plugged in" and didn't worry about anything, ignorance was bliss!
Thank you!
