I've had my Focusrite 18i8 for about 2 years now and it's performed flawlessly. Went to record yesterday and the recorded input from XLR input 1 is very low and muddy. Nothing has changed in my recording setup. Could the input channel have gone bad?
Dale
Focusrite 18i8 Port Problem
Re: Focusrite 18i8 Port Problem
Input 2 as normal?
Any changes in F/R software?
- shufflebeat
Longtime Poster - Posts: 9728 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
Was it a microphone or instrument you had plugged in? Any chance you could have accidentally flicked off phantom power when you plugged in?
Are the other channels still working properly?
Posts: 28072 Joined: Sun Jul 05, 2015 12:00 am
Does the 18i8 use the Scarlett MixControl software? Anything changed there?
dalezjc wrote:I've had my Focusrite 18i8 for about 2 years now and it's performed flawlessly. Went to record yesterday and the recorded input from XLR input 1 is very low and muddy. Nothing has changed in my recording setup. Could the input channel have gone bad?
Dale
It would be quite rare for a single channel to go bad in the way you describe, I wouldn't say impossible, but rare.
Are the gain halos behaving in a similar manner if you switch between CH1 and CH2, i.e they both light green at roughly the same points given the same level of snare hit? Is this behavior both mic and inst input, if you plug a guitar / bass into input 1 does it have a lower level and quality of sound compared to input 2. I'm wondering if the combi jack has somehow become damaged on the first input channel, in the scheme of things CH1 inputs can sometimes get the most wear in terms of plugging things in, if I were to think of one thing that mechanically might fail.
The pot might be a problem point, but I would normally expect crackles to be apparent.
Is the mic dynamic or condenser? The phantom should be the same on 1 and 2, so if one was problematic I would expect the other to be the same, but wondering if dynamic and condenser mics show the same behavior.
If you listen on headphones is the difference between CH1 and CH2 equally as apparent?
It's probably worth getting in touch Focusrite support, they might ask similar questions, the more things you've tried up front might help with diagnosis.
Joe
blinddrew wrote:Does the 18i8 use the Scarlett MixControl software? Anything changed there?
That was what I had in mind rather than any updates.
It doesn't take much to get lost in mix control but you could load <file/whatever the initial preset is called> to eliminate the possibility of an inadvertent tweak.
- shufflebeat
It's not entirely unknown for electronically balanced input stages to get blown up, especially if 'hot plugging' mics with phantom power switched on. And the symptoms of low level and muffled sound more like a broken input stage rather than a software mixer setup problem...
That being said, combining two of the same signal with a slight delay between them can produce a sound with a similar description (low level) too, so it is worth checking that you haven't got any weird signal routing going on!
Posts: 42194 Joined: Fri Jul 25, 2003 12:00 am
